Mine did that when the injector washers were stuffed.... also the plastic valve in the return line on the fuel filter can cause issues with power loss and smoke on startup( little plastic insert inside the brass fitting the fuel line conects to).. if it's buggered enough and you park pointing uphill the car will refuse to start... u have to either purge thing to get it going
Loose intercooler hose??
Cheers mark
