 Master
						Supporter
						Master
						SupporterPerhaps my search skills aren't up to the test but I can't seem to find the answer to this anywhere?
I serviced the whole car on the weekend and now want this message gone, does anyone know how?
 Wizard
						Wizard
						You could try this but I'm not guaranteeing it..
To turn off the Oil Service Light on Land Rover LR4, conform to the following instructions:
Turn the ignition on
Open the bonnet
Open the drivers door
With push-button start, press and hold the ? Start? for two seconds without touching the brake pedal.
Next, simultaneously press the accelerator pedal and the brake pedal and hold for a minimum of 10 seconds, until a ?SERVICE RESETTING.? message shows on the instrument cluster display.
Turn the ignition off and back on
If the message is not cleared, repeat the process
From another site - untested but won't hurt to try
 Master
						Subscriber
						Master
						Subscriber- Justin
Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
Moved into MY12 L322 4.4 TDV8 Autobiography
VK2HFJ
 Master
						Supporter
						Master
						SupporterJust so I can be sure I'm understanding correctly as it hasn't worked so far..
What do you mean by turn the ignition on? Is that not the same as pushing the start button without the brake pedal?
I tried from inside the car
Lean over, pop the bonnet
Then open drivers door
Then press start button (no brake pedal)
Then depress brake and accelerator for 10 seconds (or more)
But no luck, did I misunderstand something?
Just buy a resetting tool from Blackbox Solutions in Cyprus.
 Swaggie
						Swaggie
 Master
						Supporter
						Master
						SupporterThat's why I asked what turn on the ignition means, I confused how that is different to pressing the start button without the brake?
