Results 1 to 10 of 13
Thread: Dead battery!
    Jul 2013
    Dead battery!
    Murphy's law at it again. Supposed to get on the road to go to Perth today and the disco's battery is dead!Anyway I put it on charge and it may end up a non stop trip (1400km). Any decent places in Perth to pickup a new one that have them in stock?
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Apr 2015
    Lillyfield NSW
    Batteries can sometimes die suddenly when the sediment from the sacrificial plates ( Anodes ), builds up to and shorts out the Cels.
    If you carefully and slowly drain the acid into a clean container, flush out the Cels and replace the acid, you might be able to get a charge into it. All it will cost is the clothes you're wearing. They always seem to come out of the wash full of holes, no matter how careful you are.
    Of course the best option is to go to Town and get a new one.
    Cheers, Billy.
    Keeping it simple is complicated.
    Be careful - batteries are filters for modern vehicles - if a cell has gone you may not make it regardless.
    Jul 2013
    Quote Originally Posted by cuppabillytea View Post
    Fully sealed battery so thats not really an option.
    Gonna have to risk the run as I can't get a battery locally either way
    Shane
    Dead battery!
    Make sure your Roadside is up to date just in case
    If it drops the ECU will freak and may shut down
    Jul 2013
    Might not end up going anywhere at this rate as with a few hours charge I can't start the car on the current battery anyway.
    Is there any tests I can do with out the car running to eliminate the alternator as the cause?
    Shane
    Apr 2015
    Lillyfield NSW
    Thanks Tombie. I didn't consider that. Still living in ancient times, at least when it comes to Electricery.
    Cheers, Billy.
    Jul 2013
    Well done a basic load test on my old cranking battery with a spare 55w bulb. Volts dropped of very quickly so looks like the battery is dead. After saying I wouldn't be able to get a battery locally, looks like I'm kinda wrong there. Couldn't get the exact same MF88H (supercharge) battery, but they did have a center din85l. Same physical size just not as tall and 780cca vs the supercharge 880cca. It'll do for now and gets me to perth where I might pick up the slightly bigger battery - thoughts? Really needed or would this one do you think?
    Sent from my GT-I9505 using AULRO mobile app
    Shane
    Canberra, Australia
    Shane,
    I take it you do not have a second battery fitted? Easy to reconfigure the cabling to use this instead of your existing starting.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Jul 2013
    I do have a second battery, tried jumping off it at the start and didnt have much luck (it did have the fridge running off it overnight so was a bit down on voltage)
    Shane
