Results 1 to 10 of 16
Thread: Clutch issues? Help would be appreciated
    Jan 2017
    Hallam Vic
    So got the newly acquired v8 County home and gave it a good clean, put some petrol in other and if roared to life. Clutch however isn't so keen. Pedal is on the floor and I can put it in gear while engine is running 😲. Feels like clutch is jammed open if that makes sense. Any advice would be greatly appreciated. Andre
    Douglas Park, NSW
    Quote Originally Posted by bluebike0 View Post
    Pedal is on the floor and I can put it in gear while engine is running ��.
    I'd be happy with that as it sounds normal so far .
    Does the pedal come back if you take your foot off it? If so, does the car move?
    If the pedal is stuck down, then the master cylinder is probably seized.
    Apr 2015
    Wellington NZ
    Talking
    Might the system need flushing through....?👍🏻
    Jan 2017
    Hallam Vic
    Thanks Scott. No it doesn't move even in gear with engine running. Pedal is able to to pushed in but has absolutely no resistance. Hoping it may just be slave cylinder.
    it may be the slave thats siezed or the throw out thats siezed.
    to tell fit a blanking fitting to the flex line and try the pedal. If you can make the pedal lock up near the top then its the slave or the throw out.
    it could also be the flex line collapsed and not letting the fluid come back. but that usually results in a heavy footed bugger like me bending the push rod.
    you could also have a combination of issues with the throwout being stuck and a leaking/air filled slave/master cylinder.
    Jan 2017
    Hallam Vic
    Thanks mate, will attempt to have a look at it this weekend, fingers crossed.
    Jan 2017
    Hallam Vic
    Still searching for answers. Loosened slave cylinder but no joy yet. Car starts and you can select any gear you like with engine running and clutch out and it does not move, did notice front prop shaft spinning though.
    Jan 2017
    Hallam Vic
    😊Any LR experts in the se suburbs of Melbourne??
    Douglas Park, NSW
    You don't need an expert. You have something broken in the front diff/axle if the front propshaft is moving & the car isn't.
    Put the transfer case into difflock - the rear propshaft will move now, along with the car.
    Feb 2014
    You don't need an expert, give it a go yourself !!
    Sounds like you have two problems.
    As Scouse said lock the centre diff first and if you then have drive I would check the front side shafts, drive flanges and cv's. YouTube is your friend with this. Plenty of video available on how to remove/replace them.
    As Dave said if the clutch is still not engaging it must be a seized slave cylinder or release bearing.
    To eliminate the slave remove it completely from the bellhousing. If your clutch still isn't engaged it must be the release bearing.
    I suspect however that once you engage the diff lock you will have drive but the clutch wont disengage. Same culprits are likely. My money would be on the slave cylinder though.
    Good luck!
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
