If Aaron40 doesn't see this thread,send him a PM.He has adjustable stays on Fyrlytes,also has no bar.The actual bracket came from a WA auto electrician I believe.
Andrew
Hello folks,
I currently have the genuine LR driving lights on my D3 which are rubbish and I am wanting to fit Fyrlyt nemesis 8000 to it.
The current setup is bolted to a steel flange then extends down through the top of the plastic bar and onto a crossmember. Very rigid and secure.
The top of this flange is about 2" lower than the top of the plastic bar.
I am thinking of getting some brackets made up that can be bolted to the existing flange and will extend up enough to provide adequate clearance for mounting the lights. The part would have a suitable tounge welded to it.
Anybody know a fabrication shop that can do this sort of work? Bit of maching to make the part for the top of the flange I would think.
P
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Thanks Andrew. Cheers
D4 MY16 SDV6 HSEe-diff, IID, LLAMS, ARB Summit bar & Intensities & twin compressor, Traxide, GOE sliders & guards,
TowPro Elite, Mitch Hitch, Rhino platform, Drifta drawers, GME UHF, ProSpeed rear ladder
They list them on eBay for $395. That's a tad too much imo.
http://m.ebay.com.au/itm/LAND-ROVER-...-/222357142306
2007 Audi RS4 (B7)
I had a look at the fleabay listing, it's for a D4 only. I have contemplated getting something made up in similar fashion, just need to find a suitable fabrication shop.
$395 is probably reasonable.
thanks
Peter
