Results 1 to 10 of 14
Thread: ok i've had enough
    Ferntree Gully VIC
    ok i've had enough
    i've had enough of my front wheel bearings letting go on a regular basis
    so how do change them to oil instead of grease?????
    i need all the details please
    and any sketches or diagrams you might have and part numbers
    thanks guy's
    130's rule
    Toowoomba QLD.
    Re: ok i've had enough
    8O 8O How regular is regular? Must be crap bearings and or seals!
    Trev.
    Narre Warren
    I'd not recommend doing that Ray. Years ago the Army went to packing the wheel bearings with grease rather than oil on the old Series 2s because the seals were forever failing and oil ****ing out everywhere. Perhaps a thicker grease may help. I'd also stick to waterproof grease if you're not already.
    Ferntree Gully VIC
    Originally posted by disconut+--><div class='quotetop'>QUOTE(disconut)</div><div class='quotemain'><!--QuoteBegin-hiline
    Trev.[/b][/quote]
    after a good mud run :? :?
    they dont seem to last long after that
    130's rule
    Ferntree Gully VIC
    i've herd a few stories of guy's running them in oil and never having any drama's with them
    just sick and tied of doing them every 6months or so
    130's rule
    Toowoomba QLD.
    Originally posted by hiline+--><div class='quotetop'>QUOTE(hiline)</div><div class='quotemain'>
    Trev.
    they dont seem to last long after that [/b][/quote]
    So the issue is the mud. Not the bearings. Why or how is the mud getting in?
    If you can't keep mud out, you are never going to keep oil in!
    Trev.
    S.W. Sydney
    theres no drama runing oil insted of grease much better but it sounds like you are geting mudie water in through the wiper seal on the big crome ball when you run grease the grease picks up all the fine bits of dirt in the water and then works just like a grinder on your wheel bearings
    pull everthing off tight down to the axle end clean everthing up put new wiper seales in and dubble the steal plate that holds the wiper seal (every 110 axle we built we put two of the big steel plates on and no more problems with leaking) i guess you are already runing breathers on the swivle houseing so this should fix all your problems
    Tony
    Padstow NSW
    Ray,
    pull the hub and stub off the swivell ball, can check the cv's and
    axles while in there.
    in the back of the stub axle theres a needle roller bearing and a seal.
    use a screwdriver to pull the seal out.
    put it all back together jobs done.
    the only place mine leaked is the bottom swivell pin(the two bolts)
    i drained it out sealed the bolts with 510 loctite and bobs ya uncle!
    this is the stub and in behind the roller bearing is the seal.
    this is the swivell ball housing. at the bottom you can see 2 bolts, remove
    clean and seal.
    hope this helps.
    phil.
    Padstow NSW
    <div class='quotetop'>QUOTE</div><div class='quotemain'>double the steal plate that holds the wiper seal (every 110 axle we built we put two of the big steel plates on and no more problems with leaking)[/b][/quote]
    my manual says that there should be 2 plates also, but the ones on mine only had one. and i can now see why 2 are required! one just aint
    enough to hold the seal in tight.
    phil
    Avoca Beach
    Why not pressurise the swivels and hubs with a small ARB? compressor..
    You wil blow some oil out but better than bearings every six months.
    I do not see how you will ever keep mud out any other way.
    Regard s Philip A
