Thread: Rear windows not working
    Feb 2013
    Ballarat,Vic,Aus
    Hi Guys,
    I've knocked something off somewhere ..... Any ideas ? Both rears have stopped working, but I have had the car in bits over the last 6months. I pulled the little relay unit out from beneath the cubby hole in the center console. It seems to work. There is 5 relays in it, four of them wind the front windows up/down ... IS the fifth one that powers the rear window ? ... maybe ? The must be relays somewhere for the rear windows ..
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Dec 2014
    FNQ
    Shane,
    There's a write-up on discoweb regarding cold solder joints in the window lift ecu, and there is also another repair process on atlantic british - except they want you to pay money for a wire splice...
    Land Rover Window Lift Repair Kit
    apparently the window lift ecu is notorious for failing.
    I think I only have relays in the centre concole space behind the handbrake.
    If I can dig up some more info, I will.
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
    Gosnells
    Amen and Amen, the window ECU (behind glove-box in my '95 softdash) WILL have 'dry' solder joints... If not, it WILL develop them... Mine HAD them and now they're fixed... First the REAR windows when I bought her, and last year the passenger-front window failed to proceed.
    Remove the sinning circuit board, and look carefully at the 'heavy' joints around the relays and the harness connector.
    Feb 2013
    Ballarat,Vic,Aus
    Thanks Guys,
    this one is a '92 hard dash. The window unit in the center console seems to only have 5 relays in it ( 4 for up/down front windows ... and maybe one for the power feed to the rear window buttons) .... But where is the rear window relays ?
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Dec 2014
    FNQ
    Shane,
    I wrote a reply to this earlier this morning but when submitting, found the site to be 'unresponsive' - i.e. Dave had taken it offline for upgrades.
    I've sent you a PM>
    Feb 2013
    Ballarat,Vic,Aus
    Quote Originally Posted by Mercguy View Post
    Shane,
    I've sent you a PM>
    Thanks Joe,
    sorry for the delayed reply.... I've been a bit busy the last few days I'll see if I can't find those rear window relays using the diagrams!
    seeya,
    shane L.
    Proper cars--
    Modern Junk:
    DiscoMick Guest
    Also, on another tack, check the wiring running from the body to the doors has not been pinched. It happened to my Defender.
