Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: D3 DRL Replace Fog Lights Any Problems
    Jun 2008
    Hi All,
    I have just ordered LED replacements for the fog lights, but am now wondering if there will be any electrical problems with not having the electrical resistance of a incandescent bulb in the circuit, cost of the two lights is only $10 so they will find another use if there are going to be conflicts with the car.
    2x Bright 18 LED Round Daytime Driving Running Light DRL Car Fog Lamp Head Light, approx 90mm round and 83mm deep.
    Ryall
    Apr 2010
    sydney
    I replaced them with the LEDriving Osram ones (bit too expensive, but worth it for the DRL function). No issues with electricity. The LED fog light component isn't that good, not better than the original halogen lights, but the DRL component is awesome.
    Feb 2009
    Quote Originally Posted by irondoc View Post
    My Osrams seem to have developed a mind of their own. On when the car is off and vice versa. Great when they're working. Like the car!
    Anyway I don't think the fog light current would cause issues like faulty brake light switches. $10 is a cheap experiment!
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Apr 2010
    sydney
    I had to put a separate relay in when I wired the Osram DRLs up. They have some funny voltage sensing thing, and I have a solar panel on the roof. When it was sunny and it got above 13V, they would come on as they would think that the engine is on.....
    Stuart, it sounds like you have one of the wires wired up the wrong way.
    Keep in mind also - removing Fog Lights - no matter where you live - isn't a legal thing D3 DRL Replace Fog Lights Any Problems
    Feb 2009
    Yeah oddly they worked fine for ages. I followed the instructions to wire them up. I'm wondering if it's an old battery thing. The alternator is still putting out 14.4 V but I've been doing a lot of short trips.
    Jun 2008
    Thank's all, and it looks like I may have just bought some work lights for the caravan as I hadn't thought of the legality bit seeing as they were marketed as DRL/Fog lights and they should fit where the fog lights are as a direct replacement for them but Tombie is right, if it aint legal, it aint, and as it's meant to be seen it will be by any passing officer.
    Ryall
    Just check.. they may have both functions.
    Oct 2012
    Has anyone any tips on how / where to get a wire through the fire wall to the glovebox fuse box
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by orangepop View Post
    There is a spare grommet in the aux battery box (where abs pump is ) on driver side .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
