Results 1 to 10 of 13
Thread: 300tdi Vibrations / low power around 3000-3400rpm
    Mar 2015
    Perth, WA
    Hi,
    I have a 1998 300TDI 110, its done 380,000kms but the previous owner swapped the engine with a rebuilt one about 60,000kms ago.
    Ever since I have had it has had a vibration and loss of power as you get just above 3000rpm, it feels like a drivetrain vibration (I can feel it through the seat and the floor), but its at the same RPM independant of gears, and it seems to loose power at this point to so I am guessing it is engine related.
    In neutral the engine will rev past 3000rpm without any vibrations like this that I can detect, and it seems to be worse the more load on the engine, ie if I let it rev past 3000rpm at half throttle in 1st or 2nd gear its not nearly as bad as 3rd or 4th gear and full throttle.
    I really haven't worried about it as most of the time I tend to shift gear around 3000rpm max anyway, but recently doing a long trip towing a car trailer it was quite a pain not being able to rev just a bit higher before changing up gears.
    If I do let the engine rev past 3000rpm it seems to actually pick up power / torque again at around 3400rpm. Which makes me think something is not right, but I have no idea what.
    Any suggestions for what I should look at / check?
    I have only changed fluids / filters and gaskets to fix leaks on the engine since I have had it, but it has also been serviced twice by landrover specialists so I would have thought they would pick up anything major, but I haven't mentioned it at the times of services as I have needed other things fixed at those times.
    St Helena,Melbourne
    4.28 MB
    Sounds a bit like the cam/ pump timing might be out a little bit.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2007
    Living the dream!
    What he said.
    Otherwise, was the turbo replaced or is it original?
    If it revs freely without load but struggles with load i suspect trubo or somewhere else in the air system (filter etc)
    Mar 2015
    Perth, WA
    Not a clue about the turbo being replaced or not. I believe the engine was actually rebuilt by the previous owners dad, or was a rebuilt one he had as a spare. Either way I have no paperwork as to what was done. They did have three defenders other than this one I bought, so I assume they knew a little bit about them.
    boost pressure holds pretty consistently at about 13psi all the way to 4000rpm.
    Quote Originally Posted by SSmith View Post
    What he said.
    Mar 2015
    Perth, WA
    I might have a look into the procedure for checking timing. From memory there is a pin that should insert somewhere to verify the pump timing, and cam timing would just be marks on the gears lining up?
    Nov 2015
    Tamworth
    Youll need a timing kit - this vid will help on how you do it with the timing cover in place:
    Bosch VE Pump timing check with cover plate on - Land Rover 200tdi and 300tdi diesel engines - YouTube
    Mar 2007
    Living the dream!
    Quote Originally Posted by mattims View Post
    Not saying they didn't know what they were doing, at those KM if the turbo is original it is possibly just worn out.
    A 300Tdi ought to boost to 15 Psi.
    Checking the timing with the timing cover on will only tell you if the injection pump is timed, to check the cam timing the cover has to come off.
    Yes it is a pin in the injection pump (a drill bit will do the job in a bind - I cannot remember size, sry) and lining marks up on the cam and crank, try a search - there are some very good write ups on the procedure
    Sep 2010
    The Hills.
    152.79 MB
    9mm does it. The pin I have is 9.25mm.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2010
    The Hills.
    152.79 MB
    If you are going that far then it's madness not to change the belt IMO.
    Dave Blknight has a good tute for that. tdi300 timing belt.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Geelong, VIC
    Worthwhile doing simple things like valve clearances and changing the fuel filter first before diving in too deep IMO.
    Are you running an EGT gauge? If so what temps are you seeing there?
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
