Thread: HF Radio Tuner
    Mar 2017
    Townsville
    HF Radio Tuner
    Hi All, Would any one know where or how I might be able to fit a Barrett 910 auto tuner to the Disco 4 2015. I really don't want to go down the bull bar path. I have looked at the Kaymar bar but they are also expensive. Cheers
    Jan 2017
    Sunshine Coast
    Depends on whether or not you need to tow anything, but an alternative is to make an elevated mount that goes into the tow hitch. The NSW Police had a similar arrangement on western region vehicles.
    Mar 2017
    Townsville
    Quote Originally Posted by mr_squiggle View Post
    Thanks for the info I would be towing a Coromal 662 RTV a few months of the year but that option would be ok when at home base. I had thought of a rear Ladder and making some sort of bracket off that. Any thoughts?
    NSW SW Slopes
    If you can use a single wheel carrier (rather than a replacement bumper) then fit a bracket to that, otherwise the ladder should be OK if the antenna wont foul a roof rack with the tailgate up.
    Ellendale Tasmania.
    I'll swap you our 4 channel multi tap for your autotune
    You could have a bracket made similar to how a single wheel carrier is mounted, I'm sure rijidij (forum vendor) could do something for you, give him a PM to see.
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    May 2012
    Hi,
    An auto tune antenna at the rear is not ideal unless you can get some height and space from body mass.
    The ideal position is front left. However, anything greater than 30mm in diameter facing forward is not ADR compliant, emergency services vehicles excempt.
    I tried a number of scenarios, and the best choice is a wheel carrier or a sturdy antenna mount, but it must clear rear tail gate with enough swing room otherwise you can have rear tail gate damage. You do not have much choice as any mechanism will have to be able to swing out and that means you have to fabricate it yourself.
    Shot below is my Codan 9350 Autotune on the Kaymar RWC with adjustable height when travelling to get the best efficiency where it is mounted. In addition, I can actually see it via rear vision mirrors.
    The position is not ideal, however from all reports for last 4 years, suppurb feedback across 2-30MHz...
    Mar 2017
    Townsville
    Hi everyone, thanks for your suggestions and help. I have ended up (after 10 months of grief) fitting the rear door ladder and making a bracket to fit the tuner. It has been over gravel roads and has worked a treat. Testing on all frequencies is very good quality.
    May 2015
    Mooloolah
    G'day Nike 2.
    I had thought of doing the same,but wasn't sure that there was enough support to withstand long term the pressures/stresses that are in play when on rough roads.
    Were you able to keep dust seal integrity when cabling into cabin? Photos?
    Also,how/where did you run your cables internally.
    Steve
    Ditto the Qld police. Here's a pic I took last Thursday. Click on the pic to enlarge it.
    Sep 2010
    The Hills.
    152.79 MB
    Stop it! Saw enough of those from the truck, no need to keep seeing them............. Only they NEVER smile these days..
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
