See this thread http://www.aulro.com/modules.php?name=Foru...iewtopic&t=8731 about new dashes for $200 from Land Rover
Another help type question?
I have a 94 diso that has a 93 dash in it. The Air Con has bitten the dust as I have to pull the dash off completely to access anything, I was wondering if any one has ever fitted a newer dash to their disco?
Also does anyone have any idea of the cost of one or would it just be easier to stick with the one that is in it?
I am a Fridgy so working on the A/C isn't a problem (apart from the fact that I hate working on my own stuff)
Cheers Blythe
if its a pre update Disco (200 Series) its not worth the effort really, as the pre update and Rangies of the same era have the heater and AC hoses coming from the drivers side whereas the update (300 Series) and Rangies with soft dash have the hoses coming from the drivers side.
looked like a bitch of a job!!!
LRH
Disco 4 SDV6 Auto
Disco 4 SDV8 Dual Cab Project
Disco 2 M57 Extra Cab Project
Foton Tunland Cummins ISF
Disco 1 3 door 4.6 V8 Auto
RRC V8 Auto "Classic" Softdash
RRC 300 TDI Auto
Disco 1 TD5 Auto Buggy
Disco 1 300 Tdi Auto Ute
SAME Explorer 70HP 4x4 Tractor plus Nell Loader
Subaru GDA WRX
Triumph Bonneville SE
Yamaha TTR250
Thanks LRH
the hoses on mine come out on the pasengers side. If the newer dash has the hoses come out on the drivers side it would be a neater job as the hoses currently go along the fire wall over the engine and then down and through the fire wall into the evaporator. As I have access to all the hoses to custom fit it and cutting gear that doesn't worry me.
I might look further but I guess the only prob with going to the dealer is it will also need the centre console. If I go ahead with it I will take a heap of photos and put them up so people can see for them selves if they are preparded to do the same.
Thanks for you help guys
Blythe
