Results 1 to 10 of 12
Thread: UHF aerial cable joiners
    May 2014
    Tamworth NSW
    Any advice on aerial cable joiners?
    As with the majority of the wiring on my vehicle which I've been undoing (you can read about it >>here<< ), the aerial cable was not spared the installer's penchant of 'bundle it up and stuff it somewhere where the owner won't find it'.
    Do such joiners reduce transmission or signal quality?
    Currently the aerial cable on mine runs from the aerial, thru the grille, around the firewall (via a stonkin' big bundle of mess), thru firewall and into the radio.
    Having the ability to completely remove the front grill of the defender would be good, but not sure if I put a joiner in somewhere, or join and reattach at the radio end or aerial end.
    -Mitch
    'El Burro' 2012 Defender 90.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    you do lose something at every joint
    whether that impacts your particular usage is another matter
    is there a screw fitting at the antenna end as well as at the radio end, or is it soldered?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Apr 2012
    Orange, NSW
    You need a lossless connector. I have a link for them somewhere
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    May 2014
    Tamworth NSW
    Haven't actually got that far to know what's on the aerial end. It's a GME aerial, unsure of db or whatever measure they use for these things.
    -Mitch
    Oct 2007
    Wantabadgery, N.S.W.
    Can't you unsweat the cable from the connector at the back of the radio and pull it out? (unscrew the connector first.) Tape a pull cord onto it if you want to pull it back through later. I'm no expert, but I think a join will bugger up the shielding which is vital to good function of the cable, and therefore the radio.
    Don.
    May 2014
    Tamworth NSW
    Being a shielded cable was my biggest concern. If the quality would suffer incredibly, then I'd cut the cable back down to the right length once it's routed in a way which allows me to remove the grille more easily
    -Mitch
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    If you have a heap of coax then trimming it down will reduce loss of about 0.4db per meter.
    Changing to RG316 will improve performance over RG58U.
    And if you need to fit a joiner - use an N type connector - constant impedance, therefore much more stable
    Oct 2007
    This may help
    Don.
    Apr 2016
    Country Vic.
    Quote Originally Posted by Toxic_Avenger View Post
    ..... the aerial cable was not spared the installer's penchant of 'bundle it up and stuff it somewhere where the owner won't find it'.
    I wouldn't use a joiner anywhere between the aerial and the radio. It's best practise to use a connector only at those two ends.
    But going from that description above about 'stuffing it somewhere', I'd be inclined to turf the coax and start again(ie. could be damaged already!).
    At less that $2/meter, you'd be mad not too. At about $2 each for the two N-type connectors, it's not an overly expensive exercise.
    Coax doesn't like sharp bends, so you'd get yourself 3-ish meters of new coax and keep the run as short and straight as possible. Of course dependent on where the radio box is relative to the aerial.
    Stay away from potential interference noises such as high end power cables (battery leads!).
    Always solder the inner(conductor) core. I use heatshrink on the outer sheath of the cable over external connectors too.
