Results 1 to 10 of 15
Thread: Sway bar disconnect
    Mar 2007
    Tarneit VIC
    Sway bar disconnect
    Hi. I am just wondering whether anyone here has installed sway bar disconnect on D2 to get more suspension travel.
    I think the limitting factor after sway bar disconnect kit installed is the spring and shock. Shock needs to change to longer one and spring needs to get dislocation plate. Is that correct?
    How about the D2 with airbag? Is there a dislocation plate for airbag? I dont want to replace to spring at the moment.
    Whats the maximum highest length to set on nanocom for standard airbag?
    Thanks. Gus
    May 2006
    Woolgoolga
    Shock length will be the limiting factor before swaybars and coils become an issue.
    Excessive flex is the realm of posers and does nothing for capability.. a wheel with no weight on it is no more useful than a wheel in the air...
    Mar 2009
    Port Stephens N.S.W
    I find the sway bar disconnect most useful on tracks that have lots of dips hollows and raised sections. Helps immensely to stop the side to side rocking motion the D2 gets over very uneven terrain. Yes, it works because you get more up/down wheel travel (on the front) without each side interacting with the other side. Not recommended to be disconnected at highway speeds ... Down right dangerous !!!
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    NSW far north coast
    A lot of us don't like dislocating suspension, it can be bloody unstable off road.
    You'll still get some traction from the unsprung weight of the axle housing and wheel using dislocation cones but it's a nasty way go go IMO.
    Remember that if you increase droop you also have to extend brake lines and TC/ABS cables, lower the front cross member, (the driveshaft will hit it) make sure the front driveshaft doesn't bind and has enough plunge (or install a Tom Wood shaft) and if increasing the ride height by 50mm or more you'll have to alter the castor somehow so the damned thing doesn't wander all over the road on the highway. Eccentric bushes will bind the suspension and cranked arms will probably introduce a driveshaft vibration.
    Alter one thing from factory settings and a whole raft of other things are compromised and need addressing.
    Dec 2009
    Baldivis WA
    With the ACE equiped D2s selecting low range automatically disconnected the swaybars. But it could also lock the bars if it thought a roll over was going to happen.
    Mine doesn't have ACE, but if I'm going off road having a play I remove one of the front sway bar links.
    One day I'll buy the J**p TJ disconnects, but I've been saying that for years...
    I have a 2" lift, +2" shocks, +2" brake lines, 'adjusted' ABS cables for more length and spaced the front gearbox cross member.
    Photo show how it flexes with one front swaybar link removed, rear swaybar still fully connected.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Avoca Beach
    This mob makes them.
    Expedition Exchange Incorporated :: Suspension :: SlickRock Fabrication Disco2 Front Swaybar Disconnects (D2DISCONNECT)
    I have been thinking , thinking of getting a set.
    Regards Philip A.
    May 2006
    Woolgoolga
    Does the d2 bar have the same side loading as the d1/rrc?
    Mar 2009
    Port Stephens N.S.W
    Quote Originally Posted by rick130 View Post
    All valid points for dislocating suspension but the sway disconnect doesn't fall into this category. I've run mine for a lot of years, on std suspension, and have had nil issues with brake and ABS lines. I'm not rock crawling, just touring. At 20-40km/hr speeds on rough tracks the ride is much nicer as the front axle has better articulation and walks the uneven terrain without rocking the vehicle side to side. It is of less/marginal benefit at higher speeds on outback roads.
    Kev..
    2008 Isuzu D-Max
    NSW SW Slopes
    I permanently removed 1 front link from my 1st D2 which didn't have ACE. For my 2nd D2 with ACE I made an electronic module that optionally modified the speed signal to ACE to provide a 2kph speed signal because only up to 4 kph (IIRC) would the bars be unlocked.
