Results 1 to 10 of 14
Thread: Body removal and swap Discovery 2
    Apr 2013
    Darwin
    Can anyone point me in the direction of some detailed how to's, cautions and special notices for removing the body off the chassis a D2 in order to do a body swap?
    I have had the body off on two Disco 3]s to replace engines and rebuild etc but I am looking out for the bewares and cautions of doing similar with the D2.
    I think the D3 was designed and laid out a bit more with body removal in mind (ie plug and loom connection/disconnections etc) but i would just like to draw on the collective wisdom of the forum and anyone elses experience with the D2.
    Thanks in anticipation
    Sep 2010
    The Hills.
    152.79 MB
    Hmm... no answers. I have the same questions. Anyone going to chime in?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Mar 2015
    Horsham Victoria
    No answers since 2017 Body removal and swap Discovery 2
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by RobMichelle View Post
    Yeah. You'd think that someone on here would like to share..
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    Oh well, it's only a parts car, so maybe I'll go ahead and put up a tute myself.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Dec 2017
    wandin nth vic
    Maybe its taken them so long to swap they have fallen off the perch and haven't finished. Seriously I think it would be one extensive exercise
    May 2015
    Williamstown, Victoria
    Start with a list of what needs to be disconnected. The engine and drive train stays on the chassis, so
    undo heater hoses, plug hoses and connectors.
    Steering column
    Undo radiator, inter-cooler, gearbox cooler mounts. So remove grill first, then fan, electric connections to AC fan
    Disconnect electrical connections to engine,
    Remove the coolant reservoir from its mount on the body.
    Disconnect abs connections at hubs
    Disconnect fuel line(s)
    Disconnect gear box/ transfer case linkages and cables
    disconnect clutch pipe pipe at master cylinder end.
    Disconnect brake lines at wheels.
    Remove bolts holding body to chassis.
    Remove suspension components, radius arms, Watts linkage
    remove breathers, or can these be left in situ and carefully threaded out?
    Build date 11th Oct 2003
    LROCV #1410
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Bohica View Post
    Steering column
    Thanks. I assume that the ps/ace reservoir would be left attached to the drivetrain?
    I appreciate that this is a logical process, but there are usually traps for new players.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    May 2015
    Quote Originally Posted by johntins View Post
    Ahh forgot about those. The SLS needs attention as well.
    I guess remove the PS/ACE reservoir from the body. The mechanical links from the ACE actuators and the mechanical links for the SLS.
    Disconnect the air intake from the air box, and the pipe to the vacuum pump.
    It might help to have pipes to connect to the heater core so that you can keep coolant in the core, stop it drying out, like wise on the engine side plug those pipes/hoses.
    Simple enough, when do we, I mean you start?
    LROCV #1410
    Sep 2010
    The Hills.
    152.79 MB
    Motivation is the key to that one. The car is for parts/wrecking but I don’t want to damage anything unnecessarily, but I’ll probably have to cut the body up as I don’t have anything to lift it off in one piece.
    I suppose I’ll have to de-gas the AC.
    Hmm....
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
