Results 1 to 10 of 16
Thread: Windscreen Replacement
    Brissy! No flannos here!
    Hi All,
    I've got to replace my screen up here in Brisbane North side.
    It'll be an insurance job, but I am almost certain, there will be good and bad replacement screens and good and bad installers.
    It's has a crack so still drive-able. Which is good coz the last mobile dude who replaced the screen in the D2 faffed it right up!
    What's the goss? Any tips?
    Ralph
    Quote Originally Posted by Ralph1Malph View Post
    Hi All,
    Ralph
    Do you have windscreen insurance? Insist on the genuine glass and the dealers will tell you who can install correctly.
    2003 D2a Auto TD5 good Landy gone
    2015 D4 probably the most amazing yet, why get a RR?
    Mar 2016
    You must ensure the clips for the trim along the edge are replaced with new genuine clips.
    2007 Audi RS4 (B7)
    Quote Originally Posted by Nicky View Post
    Yep, insurance.
    I'll likely lodge a claim then insist on genuine.
    Cheers.
    Quote Originally Posted by DiscoJeffster View Post
    Cheers, I didn't think of those...a must.
    Ralph
    Mar 2016
    The dudes who did mine didn't change the clips but clearly knew it was an issue. They put a huge lump of sikaflex at each clip point to assist it to stick back down securely, and I can say, it did/does work.
    2007 Audi RS4 (B7)
    Feb 2013
    Wamuran, Qld
    Fine I suppose, but I hope it comes off easily when it needs to be removed for the next windscreen.
    Ron
    2013 D4 SDV6 SE
    DiscoMick Guest
    I got mine done through insurance and I asked RACQ to tell the installer to take extra care to ensure it didn't leak, so they put that instruction on the job order. It was done in the carport while I was at work and doesn't leak.
    Mar 2016
    Quote Originally Posted by RHS58 View Post
    I found it when I installed my snorkel. Easily cleaned up and I did the same trick when I put it back on in the end. I have however been meaning to go and buy some new clips
    2007 Audi RS4 (B7)
    Feb 2013
    Wamuran, Qld
    My luck working on my vehicles is always such that I would not only break all the clips first time, but I'd no doubt bust the trim if it was sikaflexed on.
    I don't even get ****ty about these things any more - I expect them to happen no matter how careful, and just take a big breath and get on fixing and repairing the things I break along the way.
    Ron
    2013 D4 SDV6 SE
