Results 1 to 10 of 20
Thread: J MAC AXLES
    Free Again Thanks Dan
    J MAC AXLES
    does any one know if the macnamarra axles out of my rangie will fit my defender i know the spline is allright im not shaw on the length ops:
    Avoca Beach
    Doesn't a Defender have a Salisbury.
    Its my understanding, though I have never done it that the Rangie and Defender Salisbury are a straight change over, ie you can put the whole Rangie axle under the Defender or vice versa as the spring pad position, trailing arms , centre ball joint are the same. But if it is a Salisbury the axle length will probably be different..
    Again I am not certain, but if it is the later light duty axle , then logic suggests it would fit,but then Land Rover is rarely logical.
    So I probably haven't helped at all.
    Regard sPhilip A
    Well you allmost helped
    BUMP !
    so 111 people have veiwed this post and only one reply.
    so where are all these techno bods , do i have to do the old fashion thing and remove both sets of axles and measure them come on guys some one should know ops: ops:
    Ferntree Gully VIC
    just ring you know who :wink:
    he'll tell you on the spot
    9758-5777
    130's rule
    I hear you ray i did,nt think it was a hard question 8O i guess it was ill give glen a ring at roverland in ferntreegully on friday
    thanks ray
    Gilderoy, Victoria
    Surely you could ask Jac Macnamara. He did make and sell the things to you. 8O
    Mick
    1999 Land Rover 110 Defender TD5 Cab Chassis
    1985 Land Rover 110 County 4.6 EFI V8
    1993 Track Trailer camper
    thanks mick you have dealt with the man he is bad enough when your buying something imagine what he,s like when you want advice , glen would be a better option me thinks
    Avoca Beach
    Rangieman, you haven't really given the most basidc information to give an answer.
    1 Is your rear axle a Salisbury. You can tell by sticking your head underneath the back and looking to see if it has a bolt on cover plate. If it is a Salisbury , Range Rover axles will NOT fit.
    2 Later Defenders had a different lighter duty axle, and I do not know whether the Range Rover axles will fit.
    3 The point I was also trying to make is that its entirely possible in both cases that you can switch the entire axle. Whether you want to do this with a Salisbury is a moot point, but I think the later axle is just a Rangie axle with a dual crosshaft diff. I am not sure of this however . You would have to get out with a tape measure and see if the track, spring pads, etc are exactly the same.
    Regards Philip A
    ok here is the blurb im about over this .
    as states in my profile (underneath my post) macnamara diffs and axles in my rangie , banjo type diff (ok) got that
    and i have which i didnt mention (sorry) a95 defender which i am smart enough to know has a salisbury diff .
    now here we go again the defender has a arb diff lock but it has standard axles .
    now i asked if the rangie axles are the same length as a defender i know the splines are the same i just would like to know if the length is the same
    thankyou for trying to sort it out
    it is just easier to to ring a work shop i think
