Thread: nanocom readings
    Jul 2007
    jan juc
    nanocom readings
    Hi guys just got my nanocom and are wondering if these reading I got are ok
    Attached Files Attached Files
    Jul 2014
    west of Transylvania
    Hi, as long as you didnt kick down the throttle hard and accelerated gently they are OK, do you still have EGR?
    Jul 2007
    jan juc
    Angry
    Quote Originally Posted by sierrafery View Post
    Still have the Egr why shouldn't I kick down the throttle hard and why accelerate gently ? do you think is there a problem with the engine ! Just had fuel pump change at the stealers >it seems to accelerate better but the water in system is disappearing ( will look at that in the near future) but does not run like it did before
    Jul 2014
    I said about kick down cos both the boost and the air flow didnt get to highest limits but this can be due to the EGR, i didnt say you shouldn't just it's not visible in the readings that you did, better get rid of the EGR or at least clean it and clean the MAP sensor too with care as the small hole near the probe to be free cos there's the pressure reading, the probe is for IAT.... as overall readings it's not bad just it's visible that there's no full power, on a powerfull one the MAP should get to 230(1.3) and the air flow close to 600 under heavy throttle, a bit lower on autos except kick down.
    Jul 2007
    jan juc
    Thanks Sierrafery for the reply will clean the map sensor and delete the egr did wonder about the boost and hope its all runs better when done thanks for your advice.
