24th July 2017, 08:17 PM
Discovery 2 ECU
I have an 1999 Disco td5 manual and want to swap an chipped td5 ecu manual from an 2000 model. Can i do this with an plug and play and do the injectors and codes with the nano com?
24th July 2017, 09:10 PM
If this ecu is from the same car as the new motor then you won't need to do injector codes but it will need a security sync with lr scan tool
24th July 2017, 09:28 PM
Its from an year up, as mine is an 1999 and this is an 2000
24th July 2017, 10:27 PM
#4
Do both ECU's have the same part number ? You will need to read the injector codes from the old ECU (assuming they match the codes on the injectors fitted to the engine) and write them to the new (chipped) ECU, then synchronise your BCU to the new ECU. Simple task using a Nanocom.
24th July 2017, 10:28 PM
#5
In that case injector codes and security learn are required, but in your other thread you said you have a 2000 model
25th July 2017, 08:04 AM
#6
Yeah, as i have bought an another disco for parts, so the one with the ecu chip is year 2000 and mine is 1999, ill have an look at the ecu numbers and see if they match
