Results 1 to 10 of 27
Thread: What sort of kms can one expect from the Puma 2.4/2.2 engines?
    Jun 2013
    Warner Area - SEQ
    Gents.....
    Been reading some of the terrible issues that people have been having with their Toyota D4D's even after they have had the injectors replaced and I must say I'm concerned for our own '10 Prado 150. We have had our injectors replaced at 160k mark, but from what I've been reading, that may not prevent engine failure in the future..... These engines are in a multitude of vehicles and they've been around for years now in delivery vans that do huge kms, etc, and ours has now got 170k on it and I'm wondering how much longer should I keep it for....
    I'm thinking if I get rid of our Prado, and I'd like to get a Defender Puma but I'm concerned that these CRD engines also won't go the distance and will possibly also fail at the worst possible time. I've only read of a few 2.2/2.4ltr engines that have failed and these failures were blamed on a lack of maintenance. If I go down this path, I'd like it to be our last touring vehicle that we buy, so I was wondering what sort of kms have owners gotten out of their CRD Puma Engines? These engines have been out for years so there must be a few now with some very high kms on them by now....
    If possible, I'd like to hear from Puma Owners and how many kms they have on their engines and which engine they have (2.2 or 2.4ltr)? Also if u have ever had any engine problems, I'd like to hear about it as well
    thanks in advance.....
    Sep 2016
    No CRD engine will be as reliable or as long lived as an older engine like a 200/300tdi or td5. However, some are better than others. Your toyota engine should last a while yet, while a puma engine probably won't be as reliable. AS always though, preventative maintenance is key. I've seen d4d's die with less than 70 000km and transit's with 400 000km on the original engine. It all depends
    Nov 2014
    Sydney NSW
    Plenty of transits on carsales with 250k plus kms wjth the puma engine. The puma engines have been known to last hundreds of thousands of kms in tranists, mondeos and i have no doubt the same in the dedender.
    Torres Straits
    They don't call em d4dead for nothing....
    If the 4cylinder d4d had a Nissan badge in front of it it would be known as grenade mkII
    S
    Jun 2013
    Warner Area - SEQ
    Quote Originally Posted by REDTD5110 View Post
    I'd be hoping for the later - 400000kms+ but I assume because of the numerous Transits, etc that run the puma engine, that a replacement engine should be reasonable in price.... I assume it would be cheaper than the toyota d4d replacement?
    Sep 2016
    I'd assume either engine would be easy to find. Plenty of both are around. Price wise I have no idea.
    Jul 2009
    Melbourne, Victoria
    The December 2010 Transit I have for work has just hit 215,000 km. It has the 2.4 engine. Overall it has been reliable. Still has the original EGR. The serpentine belt lasts 100,000 Km and needs to be replaced which takes 10 minutes. Crank shaft pulley died at 130,00 km. Rubber bonding disintegrated. Not cheap but not too hard to replace.
    The inlet manifold gasket developed a leak which caused a few error codes and rough running until replaced. The Ford dealer was going to replace the turbo and/or injectors (fault codes logged in system) but I pointed out that the occasional rough running had only been happening since the leak was evident. 20,000 km later, everything has been fine with rough running resolved. It sometimes throws a turbo under boost/over boost code but I just clear it and continue on. Probably happens every 10,000km. I used to worry but have now got used to it. Oil is changed every 15,000km as per service schedule. Luckily my Defender does not eat brakes like my Transit. I don't have to add oil and fuel consumption is consistently 10.8l/100km for a LWB high roof Transit weighing in at 3.2t. Better than my 2.2 Defender!
    I will keep an eye on my Defender coolant hoses (there are lots of them) as the Transit hoses wear on each other, even keeping in mind the vehicle drives on 100% bitumen. Once again, I had to point this out to the dealer and ask for a number of them to be changed otherwise I might have had a blown engine if the hoses had burst. Everything is so squashed in around the engine bay that this type of wear is almost a certainty.
    Jun 2013
    Warner Area - SEQ
    Quote Originally Posted by 4wheeler View Post
    Cheers for that.... 215,000kms is good & some good info to keep in mind.... but still that sort of kms is still fairly young for a diesel. By the time I get around to afford to buy one, there's a good chance that it will be well and truly north of the 200,000km mark, so does anyone have higher kms on their pumas?? +300,000kms??
    Safety Bay
    It will last longer than the vehicle. Pat
    Melrose SA
    Quote Originally Posted by PAT303 View Post
    Didn't realise that Puma build quality was that bad.
