Results 1 to 4 of 4
Thread: Any advice for changing a kickdown cable
    Jun 2014
    Hawthorn
    300tdi disco
    So just now waiting for my kickdown cable to turn up and then it will be getting installed as current one is snapped have asked a few people for advice but seems no one has ever changed one, anyone on here had to change one and can offer any advice would be greatly apprieciated
    Jul 2014
    west of Transylvania
    If you dont get some valuable tips this is all i can help :
    Sep 2013
    Darwin
    12.74 MB
    Did it once years ago. This video will give you a guide. Don't recall taking the valve box off. Remember minor trouble getting a rubber boot on the cable end to go into position, inside the gearbox. Otherwise no real dramas, just tedious. Didn't need special tools. Lots of dripping oil. Change your filter while in there?Range Rover Classic Kickdown Cable - YouTube
    St Helena,Melbourne
    4.28 MB
    Trans sump off, valve block off to get to the cable attachment, make sure everything is spotless clean.
    From memory most guides say to remove the crossmember but i only loosened the LH mount to get the sump off, hardest part was re-routing the cable over the bellhousing, fit a filter kit while you have the pan off - wear disposable gloves.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
