Hammer it in to the end of your jack to extend the reach; as it now has further to span to reach the jacking holes in the chassis.
Pictures:
defender a frame bar - Defender Forum - LR4x4 - The Land Rover Forum
Came with my A frame bar and I have no idea what its for, but its solid like its to do with jacking?
Pictures:
Interesting, I dont recall that page in the instructions, but i have a bottle jack that lifts by the axle and nothing that resembles the part in the picture. Was a different jack used on earlier models?
Defenders should all have a jack like that one in the pictures. If Pumas don't it is due to a cost cutting measure. The jack slots into the holes in the front bullhorns and the rear crossmember. Of course, you need a bottle jack as well, but the proper jack is very handy for some recovery stuff as well as suspension work.
Pictures:
LR Factory Hi-Lift Jack Kit - Defender Source
 Master
						Subscriber
						Master
						SubscriberYep JLR ditched the old defender jack on pumas. Fortunately I have one from the Tojo days.
Those pin lifters with the old hi lift are definately handy.
Hi-lift jacks are an aftermarket purchase that a lot of people make because they're useful in the bush, especially when you have a puncture and the diffs are buried. I used to keep mine on the rear of the car as you'll see lots of people doing but it kept getting covered in mud and dust so I keep it inside the car now.
Bobby
Ok, need more help from the experienced folk on here ☺. After more research I discovered that there are factory hi lift jacking points both front and back on the puma. However it was pot luck what style of jack you got. Seems like 90s and 130s got bottles and 110s got either bottle or factory hi lift. Anyhow, im now looking at a hi lift brand jack for a chrissy present for myself and in the rovacraft catalogue pg 92 they list them along with part 'DA2244' which is the jacking point adaptor for defenders.
Now, if the factory hi lift requires the extension after I installed the A frame bar, my question is whether the hi lift defender adapter is long enough to safely reach.
Dave.
