Results 1 to 10 of 26
Thread: PCI slots and Win 10?
    May 2003
    On The Road
    yes, PCI...
    this MB has one,,which is good as the two PCI-e-1 slots are just about inaccessable,,
    I have a USB 2, 4 port, expansion card of unknown quality, Device manager picks the new USB HUB up and installed something as there are no yellow error icons anymore,,
    but also no lights on the mouse I plugged in, (to all ports).
    Is it just a case of a dead card? or do I have to switch something on?
    There doesnt seem to be anything in the bios,,
    Theres a bit on the net about win 10 and PCI slots
    Apr 2016
    Country Vic.
    If Win10 picks up the USB hub, and no yellow ! icon .. then the chances are that the card and it's ports are working.
    I'd be more inclined to look at the mouse or something.
    Have you tried plugging in any other USB device type? ... something low power like a USB thumbdrive or whatever.
    I'm assuming that the mouse works on any other USB port or another PC .. if so then the next step will be ....
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jan 2017
    Geraldton WA
    If the PCI card is toast a simple USB hub that you can plug into one of the existing USB outlets on the board could be a solution for you
    4.6m Quintrex boat
    May 2009
    West Gippsland - Victoria
    So power to card should be ok as os recognises it and installed a generic driver, though in all fairness the usb 'standard' has to be one of the loosest ever so driver may not work.
    1/. can you measure 5v on the card usb connectors (may be oc pcb mount 'fuse' that feeds usb skts) on the card?
    2/. can you read chip id number which may help to choose a more specific driver ?
    Deano
    66 SIIA SWB .......73 SIII LWB diesel wgn
    86 RR 'classic'......99 Range Rover P38a
    94 Defender 110..95 Defender 130 Ute
    96 D1 300TDi.......99 D2 TD5 (current)
    04 D2a Td5..........02 Disco 2 V8
    ...Device manager picks the new USB HUB up and installed something as there are no yellow error icons anymore,, but also no lights on the mouse I plugged in, (to all ports).
    What does USBTreeView say about the functionality of the ports?
    USBTreeView
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    May 2003
    On The Road
    nice program Ferret,,
    how do I tell which is what?
    May 2003
    On The Road
    Quote Originally Posted by trout1105 View Post
    yea, and i think I still have a powered one somewhere,, but its just one more plug and cable I'm trying to do without...
    May 2003
    On The Road
    Quote Originally Posted by DeanoH View Post
    Deano
    next time I turn it off I'll pull the card and take some pics..
    May 2003
    On The Road
    you can still buy these things new,, though to be honest the OS reccomendations stopped at Vista
    Use of the bottom PCI-e-1 slot would successfully block off all air to one of the video card fans,,
    Damn You B class motherboard!
    ...how do I tell which is what?
    You have 3 problematic ports (yellow exclamation marks). Selecting them will list all the properties associated with each port which might give you a clue as to why but I have to say, much of what is reported by USBtreeView is beyond me. So I'm no help in that regard.
    However, all 3 problematic ports are on a USB3.0 hub and you say your problematic hub is a USB2.0 hub. So I would imagine the ports on your PCIe USB2.0 hub are OK.
    Connecting a known devices to any port on any of the hubs will identify each hub for you. For instance, your Evoluent mouse is connected to port 1 on your USB3 hub. What does USBtreeview show when you disconnect it and reconnect it to your problematic USB hub?
    BTW nice mouse, I have one too.
    1984 RRC, in hell
