Results 1 to 6 of 6
Thread: Rubber coupling of 94 discovery
    Is it possible to replace the rubber coupling with the usual uni joint, as I have already replaced one not long ago and this one is starting to crack aroung the bolts. What is the advantage of these?
    Bren
    Apr 2002
    Bellara 4507
    32.43 MB
    they make the drive train smoother.
    odd you should crack one quickly... you do heavy loads?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Avoca Beach
    Bet you have a lift. You just get the diff yolk and driveshaft from a Range Rover. Wreckers will have but watch the spline wear. For new shafts I found Out of Town 4WD to be good.
    Regards Philip A
    Yes it is lifted, and heavy loads not really.
    I take it the RR is about the same year level for replacement.
    Bren
    Avoca Beach
    Well I am not sure but I think any LT230 Range Rover which means prior to 89 as they went to BW then.
    But I think you have to be more careful re the diff yolk. Some are fine spline(later) and some are coarse.
    If you get new parts talk to who you buy them from. Graeme Cooper have done this many times and Out of Town would know also.
    Regards Philip A
    british4wd Guest
    Did you happen to notice if the markings on the new one had GKN on it? There are some cheap non original available which do not last.
    Alan Howard
