Results 1 to 4 of 4
Thread: Urgent Attention: D4 Disc Brake noise
    Jun 2015
    Melbourne , Victoria
    Hi, everyone. I left my D4 to dealer service and also complain about the regular noise from the brake, I had only done 16000km since replacing new brake at the beginning of the year. I haven't done much off driving or pull the 1.5 tone trailer for a thousand km. They claimed nothing wrong with it, but the disc is less 60% now. They found nothing as I complained, anyone has the similar experience. I had new brake pad installed last Christmas, it got handbrake fault after 5000km to Fraser island trip. The dealer replaced disc brake as well at the time, I suspected they have the constant issue with disc brakes rather than I had been towed hard or too much offroad driving as they indicated.
    Any help is much appreciated!
    Gary
    Gary
    MY15 Discovery 4 White, ARB Summit Bull Bar, Runva 11XP Winch, LLAMS, Icom440, GME 4705 High Gain Antenna, Redarc tow pro elite. 18" GOE Rim & BFG 265/60R18, APT Compressor Guard & Air Tank Guard. Outback Long Range Tank & Spare Wheel Carrier.
    Oct 2013
    Old Toongabbie, Sydney NSW
    Quote Originally Posted by DIS4 View Post
    Gary
    Hi Gary
    Just had my front and rear pads replaced at 4 year service with 26600km. They probably could have gone a couple of thousand more so your 40% for 16K would equate to 40K for 100% which is more than I got. But, I do city, stop/start driving so probably heavier on brakes than a country car for example. I understand that the LR brakes are softish from what I've read but they do the job well.
    Martin
    May 2016
    Londonderry, NSW
    Gary
    Some pads are soft, are you saying the pads have worn 60% in the time frame. Is front and rear the same. Have they got the "anti chatter" bits fitted (a metal piece). Do you drive with your foot resting on the brake pedal. In one manual I read they recommend changing disks every second pad change as worn disks can wear pads quickly.
    Tangambalanga
    My cars just done 45k and had the rear pads done only.
    Car will be be in for service after Xmas and we’ll see how the fronts are doing then.
