Results 1 to 10 of 13
Thread: Discovery 4 disc brake replacement? Any recommendations pls?
    Jun 2015
    Melbourne , Victoria
    My local dealer told me that my disc brake only last around 5000km, which cost me $1600 for the front pair, $1000 for the back? What the rip off! Any good supply in Melbourne? How much cost to you, a mate told me around $500 should be reasonable. Any tips please?
    Gary
    Gary
    MY15 Discovery 4 White, ARB Summit Bull Bar, Runva 11XP Winch, LLAMS, Icom440, GME 4705 High Gain Antenna, Redarc tow pro elite. 18" GOE Rim & BFG 265/60R18, APT Compressor Guard & Air Tank Guard. Outback Long Range Tank & Spare Wheel Carrier.
    Mar 2016
    Were you doing a lot of towing during that 5000km, and your brake controller isn't setup well, meaning your Disco was braking the majority of the load? Failing that, I can't understand that. I'm up to 60,000km on my fronts and they've still got another 20,000km in them I expect.
    Get yourself to an independent and get it done for a quarter of the cost, or DIY it. It's a pretty easy job.
    2007 Audi RS4 (B7)
    NSW SW Slopes
    I think that Gary means only 5K of wear left.
    Dec 2011
    Adelaide
    142.79 MB
    Mine is a D3 not a D4, and I've just ordered a set of Akebono's from the US, front and rear, for less than A$300 shipped.
    At this stage, I'm only doing pads, not rotors.
    Not sure if the D4 is different.
    Plan to fit them myself - I did my old Disco 1 and my Perentie, so this one can't be much different.
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    Ean Austral Guest
    Look for Bodsy's brake bible on the Disco 3 UK site. I can't post the link but it may even be on here somewhere.
    Its a step by step for all the brakes on a D3 , can't see the D4 TDV6 being much different, not sure about the 3.0 but it can't be much different
    Cheers Ean
    Dec 2011
    Adelaide
    142.79 MB
    Quote Originally Posted by Ean Austral View Post
    Cheers Ean
    You mean this one!
    https://disco3.co.uk/gallery/albums/...le_V1.4sml.pdf
    REMLR 012
    Sep 2014
    Baldivis WA
    Hi,
    I replaced all 4 rotors and pads at around 100,000 kms. The OEM rotors are softer than aftermarket, the trade off being that they give more brake bite.
    I would suggest replacing pads and rotors at the same time.
    at the next service I had the brake fluid flushed and changed.
    i went for the DBA “kangaroo paw” solid rotors (no need for drilled or slotted ones) ordered via Coventrys auto parts. I also went for Bendix brake pads all round, however in hind sight should have gone with Ferodo pads for the front, as the Bendix 4WD pads are the dustiest pads I’ve ever run.
    all up cost me 600-700 bucks. Fitting is really easy, remove wheel, undo pad retaining clips and remove old pads, undo brake caliper mount bolts, remove caliper. I tied mine out of the way with a zip tie. Und the rotor mounting socket head cap screw and remove.
    fit new rotors and pads and replace wheel. Repeat at all remaining corners. I worked on from two then back two. Took about 3-4 hours total, as I also cleaned the rims inside and brake calipers(with brake cleaning can).
    if I was to do it again, i would take the time to paint the DBA rotor hubs, as they surface rust. The oem rotors have a nice grey primer coat. I’m now at 174.000 km and will replace front pads with Ferodo Pads in the near future. The rear are still Bendix and not dusty at all.
    from eBay a set of front pads is about $75.
    the oem costs are rather high.
    PeterJ Guest
    There is another thread here Disc Rotors & Pads Front & Rear
    that has quite a lot of discussion on this as well, worth a read.
    I went through this exercise just recently, in the end only needed some rear pads at this stage. Repco had brake pads on sale, ($75) and to my surprise had the HD Bendix pads in stock, so keep an eye out for sales and you can save a bit.
    Just FYI even though the pad wear sensor is on the RH rear inner pad, when I checked pad wear during service I found LH Rear inner pad to be the most worn.
    Peter
    Feb 2012
    Darwin
    Quote Originally Posted by PeterJ View Post
    Peter
    I thought each wheel was fitted with a wear sensor?
    Cheers, Mungus.
    _________________
    MY14D4HSE, Nara Bronze, E-Diff, Vision Assist, Surround Cameras, LLAMS, ProSpeed Sliders/Compressor plate, Mitch Hitch,
    ARB Summit Bar, Runva 11XP, Traxide D3-DU, GOE Comp. Rims, D697 265/60R18, Rijidij RWC, Fyrlyts.
    Sep 2014
    Baldivis WA
    Also, I ordered two new wear sensor leads one front and one rear. I did break one when taking it off the caliper, the sensor end looks like a bake-lite type material and must get a bit fragile from the constant heat cycles. A set of aftermarket sensor leads from Rovaparts was about $25 for the rear and $40 for the front see link: Land Rover Parts - BRAKE PADS
    Really easy to replace.
    Wear rates have been ok, I just found the Bendix 4WD really, really dusty.
    i was also looking at a set of the Kevlar pads offered by Pedders: http://d22enj1fxubdc2.cloudfront.net...er-euro-35.pdf
    cheers,
    Eric
