Results 1 to 10 of 40
Thread: Alternator — preventative servicing
    Feb 2009
    In a few different threads recently, people have mentioned preventative servicing, via replacement, of the alternator. I thought I would start a new post to see if there is a general agreement on this and when it should be done. If so, it seems like a good addition to the 'sticky' on Key Items for Servicing.
    Jul 2013
    I think it can be a good idea, but would depend on where you live and where you take your D3/4. If it never leaves a city environment then I'd just wait for it to fail as the cost to tow isn't a biggie. But if like me you live in a remote area then a failure would be a major drama so replacement would be a good idea. Question then is whats a good age to replace it?
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Oct 2016
    Perth, AU
    ...and is there any hint when it's starting to fail?
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Mar 2016
    I pulled mine down at 250,000km and the brushes were only half worn, so it’s more likely a diode failure which is at a random interval.
    2007 Audi RS4 (B7)
    Kingston, Tassie, OZ.
    I recommend 150k interval. This is based on years of experience with these engines/ alternators. I would say that rectifier failure or stator shorts to earth seem to be the common cause of death. Some pretty dramatic, too😅
    Ean Austral Guest
    I recently read a thread on the disco 3 UK site where there is a "How to" overhaul your alternator , I am not sure if the parts are available readily in Australia or what the costs are compared to a new one. Would be keen to do the exercise on the costs to overhaul it.
    I bought a new spare not long after buying the car , so will likely wait till it fails then just change it.
    Cheers Ean
    DiscoMick Guest
    I had the alternator on our D1 overhauled at about 180,000 after it started playing up. It was a while ago and I can't remember the details, but from memory the work included new brushes.
    I have heard of people having crud cleaned out of their alternators.
    An alternator is such an essential thing that you wouldn't want to skimp on it.
    Mar 2012
    Gabbadah WA
    Changed mine ay 160k , kept old one as a spare .
    Just remember that ELF are not that uncommon. So you could be removing a unit that is stable to replace with a new faulty unit or one that fails in short order!
    Ean Austral Guest
