Thread: Fuel/Water separator service cycle
    Scarborough, QLD
    I use a Donaldson P550088 fuel/water separator filter in the Defender 300Tdi. Any idea what the recommended service cycle is for one of these?
    NSW far north coast
    P550588???
    I used to do mine every service and never bothered draining between, the sedimenter catches most everything.
    Hay Point
    Pretty sure i have the same one on the 6by just after the tank switchover solenoid. I change it every 10k but then I am running bio through it. Occasionally I open the drain screw and let a little out to see what's there.
    Cheers......Brian
    1985 110 V8 County
    IIRC, 20,000km for LR serive schedule of the fuel filter. Now I guess thats as long as the Dono meets the same specs as the LR filter.
    Scarborough, QLD
    Quote Originally Posted by rick130 View Post
    P550588???
    Donaldson P550088 FUEL FILTER, WATER SEPARATOR SPIN-ON Engine & Hydraulic
