Results 1 to 10 of 12
Thread: High pitched whistling noise.
    philthy Guest
    Hi all, Just had a bit of mechanical work done on my 2000 Defender Td5 130 HCPU. The brake booster had a crack in it and was replaced with a newie. But now I have a noise that is identical to a boiling kettle on the stove whistling.Rang the shop, and they dont know without looking at it. I'll take it back but, 2 hrs drive. Just thought someone here might know. I looked all over it, checked for anything loose incl turbo bolts. Doesn't make a noise under load, but moreso while cruising at 80,100,110. Edit: Plus touching the accelerator pedal ever so lightly,the whistling will happen.
    Jun 2013
    Universe A
    Is the vehicle charging ok?
    Put a multimeter on the battery with the engine idling, then rev up,
    If the whistling changes with the volts it's possibly the alternator, I've had a couple of rectifiers go bad and they can make a high pitched whistle when they do, often they will also drain the battery when the car is turned off
    philthy Guest
    Had a new Alternator put in a few weeks ago.
    philthy Guest
    Quote Originally Posted by shack View Post
    New Alternator a few weeks ago. No whistling until this booster job was done. Did a 600km trip and whistling didn't get worse or better. Brakes working good as. The thing is,just the slightest touch of the accelarator and it'll start whistling???
    Mar 2007
    Warwick Qld
    The throttle being related to it means I'd be checking all the induction and vacuum hoses/pipes/joins/flanges. Don't just look, physically remove them and inspect closely for cracks and leaks.
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Mar 2007
    Warwick Qld
    Pay extra attention to anything they may have disturbed during the work.
    Jan 2014
    Perth Western Australia
    Perhaps more noticeable when cold, but not always...
    Exhaust manifold leak, remove acoustic cover and turbo heat shield, look at front/back for black soot on head.
    Daz
    Brisbane,some of the time.
    Exhaust manifold for sure pretty common on the TD5
    Jan 2014
    and doesnt this post really belong in the Disco 2 bit?
    Daz
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by DazzaTD5 View Post
    Yes it does .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
