Thread: A couple of newbie questions...
    Sep 2010
    The Hills.
    152.79 MB
    Couple of newbie questions...
    Sorry about this, but my thinking is a little clouded atm.
    These questions all pertain to diesel cars.
    Question 1; will an LT 230 from a D1 R380 bolt straight up to a D2 auto?
    Question 2; will an R380 from a 300 TD1 go behind a TD5 that was an auto? Bell housing aside.
    Question 3; will a pedal box from a D1 fit a D2? I think I know the answer, but hey.
    Question 4; do D1 springs fit D2s?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Free Again Thanks Dan
    1, Yes
    2, No
    3,NFI
    4,Yes
    4. Fronts don’t fit correctly.
    They don`t ?
    Id beg to differ due to first hand experience
    Quote Originally Posted by rangieman View Post
    They don`t ?
    They don’t have the tang so they don’t quite seat correctly.
    Uh huh.
    Sep 2010
    The Hills.
    152.79 MB
    I know that using a grinder on springs is frowned upon, with good reason, but could the tang thing be sorted with a little grinding, with heat being monitored, in your opinion?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    I probably should give a little background to these questions. I have been stuck in a sort of morass of indecisiveness and immobility for a few months. Now, I need to at least think about moving on. I currently have 2 D2s, one is the one famous for it's auto sagas. The other is a parts car I bought. There is also a pig of a 300TDi D1, which has the saving grace of having a MaxiDrive rear locker and of course axles, MaxiDrive front axles, and a MaxiDrive reduction LT230. I don't know the ratio, but I can say that in low range, fifth gear, at around 4000 RPM the car is doing 25 or so KM/H, on 33s. It also has the saving grace in that it actually works.
    I need to clear the decks. I am currently trying to get the parts D2 going to assess it's condition. If it drives OK, then maybe it's auto can go into mine. If it doesn't, then I am thinking that the D1's R380, which is an Ashcroft suffix L with less than 20,000 on it could go into my car instead. There must be some way to consolidate all of this into a going car and a little money left over. I am particularly interested in putting the MD TC in the D2. I also am interested in parting out the D1 to fund part of this. The D2 parts car has a TD5 that allegedly runs. It also has ACE. Maybe, just maybe, there is a path out of this nightmare with all of this.
    I apologise for the wooly thinking ( fuzzy logic, I prefer ). Times will get better, I know.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    John in short the D1 springs will go in with no mod`s what so ever and work for what you want
    I run them in mine and did not notice the said tang nor notice them not sitting correctly as Tombie state`s .
    So i guess it is user be aware that there could be issues and ramifications
    The 300Tdi R380 will need a longer input shaft to suit your td5 and then a manual ECU ect .
    Sep 2010
    The Hills.
    152.79 MB
    Thanks, Chris. The manual thing was always a long shot for my car. If the input shaft is different then that's the end of it, as I don't want to play around with an Ashcroft R380 which could otherwise be worth some money.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
