15th March 2006, 03:20 PM
What has to be done to fit 31/10.5/16 to a D1
I have a 2in lift and semi modified guards, would they still fit ?
15th March 2006, 05:17 PM
Do you mean 31x10.5x15???
If so then I still don't know
15th March 2006, 07:46 PM
Ah yes my oversight.
Forget this question, just looking to go bigger than 245/75/16.
If Cooper replace my tyres that is :roll:
15th March 2006, 09:48 PM
#4
Hi Mark
I have 31/10.5/15 Sumitomo muddies on my 95 Disco
I have a 2" lift, trimmed rear guards & no rear sway bar
The tyres barely touch the rear guards at full travel, nothing a bit of hammer work wont fix :wink:
Greg
16th March 2006, 05:26 PM
#5
A 31x10.5 is round about the same height as a 245/75, just wider. The 31x10.5 is qbout 30.5 inches in diamiter whereas the 245/75 is a sidgen bigger at 30.6 (quoted on BFG mud terrain specs, brands vary).
I prefer the 245/75 myself, not as wide and they fit inside the guard better. The 31x10.5's big advantage is that thy're cheap and plenty of brands to choose from.
Good luck with it. I know a bloke who has some 15x7 rims if you are intersted (white sunrayias). PM me if you are interested.
Trav
16th March 2006, 05:39 PM
#6
Thanks but I think I will stay with 16"
17th March 2006, 02:53 AM
#7
I've got 265 75 16 BFG A/Ts on 8" rims on my RR with standard ride hgt I just barely get away with it on road occasionally touch over speed bumps.
Big problem is the reduction in turning circle. The Highlander 2 16x8 I have on sit too far in on the RR really need 30mm spacers (big money)
Temp arrangement car will be getting lift and guard treatment befor any off road ventures.
I imagine it would be same on the Disco...depends on the offset of the wheels.
