Results 1 to 2 of 2
Thread: Solar water pumps.....
    Feb 2005
    Going to site next week to fine tune the scope.....first time player my with solar water pumps.
    Any tips or shortfalls to look out for?
    - Pumping from one tank to another
    - Tanks are 2km apart
    - Water consumption I’m still confirming, washer using 10L per truck
    - Daylight hours only
    - Working on 6hrs of sunshine...when the sun is available. Will need to work out redundancy
    - Generator input
    - Will get total elevation next week
    - Level Control, due to distance I’m thinking a float/valve at receiving tank although I’m sure there will be pressure delays.
    Kallangur, Brisbane
    You can get some nifty Point to Point Wireless I/O to start & stop pumps based on a level. See here for example: OleumTech(R) Adds Another Point-to-Point Wireless I/O Solution to Its WIO(R) System Portfolio
    I use this kind of equipment on pipelines between pump stations & storages or surge tanks for example. Elpro also have an offer.
    + 2016 D4 TDV6
