Page 1 of 26 12311 ... LastLast
Results 1 to 10 of 260
Thread: Paint
    Feb 2013
    Ballarat,Vic,Aus
    Paint
    Hi Guys,
    has anyone painted there car in recent times? I haven't painted a car in probably 8years..... so am out of touch with what the latest coatings are. I'm going to have to treat the old ****box to a splash of paint in the near future. Its some hideous faded blue at the moment (I've never been a fan of pale metalic blues and greens ......... that look sun damaged and faded from the factory).
    Is there any decent "budget" priced paints around at the moment. I seem to recall Protec was ok. The car is used, not a museum/garage princess so I'm not interested in exotic finishes.
    I'll probably just go a closed door paint job. it should only be a few weekends work I imagine.
    this is the last closed door quickie I painted:
    [img]
    they come up quite nice if you put a bit of effort into the prep. this one was PPG clear and PPG Cobra base coat. I was hoping to find something a bit cheaper given the cars usage.
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Aug 2010
    Sunbury, VIC
    Personally I wouldn't use Protec paints if they were the last company on earth as we used to use their paint exclusively at work - after corporate did a study on why machines were being painted so often they came to the conclusion we all knew to start with - the paint was garbage. Not sure if they have a budget range and a premium range but once bitten...
    I've noticed Protec are hooked up with Dulon (acrylic), which I've used for 40 years (embarrassing) with great success.
    Dunno what type of paint they were supplying your company Gav.
    The most important thing if acrylic is used is to gradually blend in a high quality clear with each coat, with STRONG UV inhibitors, with solid colours. Metallics just need it on top.
    Acrylic is so easy to use.
    DL
    Feb 2013
    Ballarat,Vic,Aus
    Quote Originally Posted by 350RRC View Post
    DL
    I've started using urethanes. I found the the old acrylic dulon didn't last very long (bird ****, sun ... everything damages it ). It sure is easy to touch up though! Metalics suck for ease of repair. Maybe I should find a "flat" blue of some sort and hit it with some "single shot" 2part urethane (ie: base and clear in one). I'll have a look around the bodywork forums and see what they think.
    If I make it look to nice .... and spend to much money on it .... It'll really annoy me the next time it does something like rub against the scenery .... Or fall on its side
    Proper cars--
    Modern Junk:
    Aug 2010
    Sunbury, VIC
    DL
    I've got a mate that ran a spray booth big enough to fit a semi in (Literally) and has used almost every brand and type of paint - don't ask him about Protec, his opinion is worse than mine. UV protection in their paint is almost non existant. It's not an issue any more as we don't use it now. It's coverage is also terrible.
    I'll use Dulon next time the POS gets a makeover.
    DL
    Feb 2013
    Ballarat,Vic,Aus
    DL
    absolutely spectacular finish ... glass like if you colour sand it.
    This is hand sanded and polished Dulon with PPG clearcoat (acrylic) over the top. I painted it about 15years ago. It still look ok ... until you look closely. Within 4 years it was quite stained where tree sap and bird **** had touched it (I did colour sand it again a few times to bring the finish back). Its also very soft and easily damaged.
    But hey .... I've had a car that looks ok for 15years now (rather than clearcoat pealing off in sheets). It also only cost me about $500 all up to paint the thing at the time ( Oneday I will have some money to spend to do something nicely ............... Maybe in another 20years ).
    I was hoping the world had moved on a bit from Acrylic laquer. I know its illegal in a lot of countries these days due (due to the VOC's and overspray). It must still be available here though. Its actually best for the home tinkerer.... as anything with an activator is horrendously toxic.... Really, far to poisonous to even dream of using (I have an air fed mask I feed from a compressor running where there is no overspray. You also have to wear painters goggles, and cover every bit of exposed skin). I have also noticed 2pack (activated) paints make me feel really crook in the guts if I'm around them while they are curing ... ""or "gassing offf" ... this can take a couple of weeks. Even POR hardnose made me feel crook in the guts to use (it is activated). Hardeners are really nasty stuff.
    Hmmm... I've almost convinced myself to use Dulon again
    seeya,
    shane L.
    Proper cars--
    Modern Junk:
    Dec 2014
    FNQ
    Killrust epoxy enamel in rattle cans.
    Why bother spending more than you really have to on the POS?
    If you want to thin it down and use stuff in the tin, dulux metalshield or killrust pretty much cheapest way to go for a rock-hard protective finish.
    or thinned down u-pol (bedliner)
    Feb 2013
    Ballarat,Vic,Aus
    Quote Originally Posted by Mercguy View Post
    Well... If I use something a little better..... The car should look quite nice.... But not too nice. I dont' want it to look to much of a ****box or it'll start to attract police attention (boss women is getting to the point where she doesn't want to get into it).
    I've just found this one ...
    1982 Land Rover Range Rover for Sale | ClassicCars.com | CC-1107010
    tuscan blue .... that looks to be a nice flat non-metalic colour. Way nicer than "faded pale blue metalic" most early 90's classics seem to be.
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Quote Originally Posted by DoubleChevron View Post
    absolutely spectacular finish ... glass like if you colour sand it............
    ...................I was hoping the world had moved on a bit from Acrylic laquer. I know its illegal in a lot of countries these days due (due to the VOC's and overspray). It must still be available here though. Its actually best for the home tinkerer.... as anything with an activator is horrendously toxic.... Really, far to poisonous to even dream of using (I have an air fed mask I feed from a compressor running where there is no overspray. You also have to wear painters goggles, and cover every bit of exposed skin). I have also noticed 2pack (activated) paints make me feel really crook in the guts if I'm around them while they are curing ... ""or "gassing offf" ... this can take a couple of weeks. Even POR hardnose made me feel crook in the guts to use (it is activated). Hardeners are really nasty stuff.
    seeya,
    shane L.
    I think I recall the stuff I used having something like 26% lead solids, which is ok with me using the correct PPE. Still got some cans somewhere, I'll have a look.
    Was mostly used on surfboards and windsurfers, under or over glass. No fade.
    cheers, DL
