Results 1 to 10 of 24
Thread: Warning D2 steering box small pipe check yours
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Just had a call from a customer that his steering box small metal pipe was a hole from a wear mark and it is gushing PAS fluid. This is the second incident of this failure I have heard of in the last couple of mouths. L/R don't list a part for this pipe, and wreckers only sell the whole box and wont part the pipe on it's own.
    So since the D2 sare getting long in the tooth it would be advisable to check yours to prevent this happening to your vehicle.
    Cheers, Mario
    Feb 2015
    Vic
    Cheers, Mario
    Happened to mine. I replaced the box
    Oct 2007
    Brisbane West
    I haven't looked at mine and it might be obvious when I do, but where is the area? Cheers
    Apr 2016
    Country Vic.
    Quote Originally Posted by ozscott View Post
    .... but where is the area? Cheers
    IIRC, you have a V8?
    It's hard to see the pipe, if it's the one I think Mario refers too.
    Small pipe that does a loop around the box.
    pipe goes from the rear of the box near the steering column shaft side, sideways and then forward to the front of the box.
    Hard to see from above on a V8 due to the coolant hoses and thermostat. Pipe is inwards of the chassis.
    if this is the pipe that Mario is talking about, what wears/rubs to cause the problem .. and is this more of a V8 or TD5 related issue(or both)?
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    This pipe as arrow points to,
    NSW far north coast
    At least that can be replicated pretty easily, or brazed if its a small hole.
    Quote Originally Posted by rick130 View Post
    Yeah, that’s an easy one!
    Jul 2014
    west of Transylvania
    Oct 2007
    Brisbane West
    Quote Originally Posted by sierrafery View Post
    Hilarious. I will.ask them whether if you pay nearly a thousand pounds for the pipe they throw the new steering box in for free...
    NSW far north coast
    Wow.
    And I wouldn't use copper either, steel all the way.
    Copper age and work hardens badly, eventually fracturing in that sort of situation.
