Results 1 to 10 of 13
Thread: D4 rear brakes
    May 2009
    St Agnes, SA
    D4 rear brakes
    During our Canning trip earlier this month the brake warning light came on after a few sand dunes. The vehicle has around 58k on it and from reading these threads, its pretty normal wear, considering the off road and towing work we do.
    Well while the D4 is back in Darwin having the EPB replaced for a second time in four months (some bull**** about clips which hold the cables in failing - no current fix) I had the dealership quote me on replacing which ever brakes were worn. So they came back with $907 to do the rears. I can do an axle of brakes including pads, discs and labour on a Volvo FH13 for less than that.
    Anyway, I figured that they would just be doing pads and wear indicator wire and i can purchase genuine parts including freight for around $250. Even if I do discs, it will only push the price up to $500.
    Firstly, taking costs out of it, is there anything in the job where it would just be better that a dealership do it?
    Secondly, does the rave CD for the D4 have the relevant information for the MY16 that I could use to carry out the job, so I have a "IAW" procedure incase of future warranty issue? (I'm a qualified Heavy Diesel Fitter with an ABN, so the legal side isn't an issue)
    Thirdly, has anyone had any experience with Brembo branded brake components on these vehicles? I have found a Brembo alternative which is slightly cheaper, and considered using it in place of genuine.
    Also open to alternatives.
    Thanks.
    '15 Discovery 4 HSE- The family bus and the kids like it!
    '89 RRC- My favorite of the bunch!
    Ex '03 Commodore 'S' ute- 450hp of uncracked 5.7lt and 6 speed manual uteness - Still crying that its gone
    Ex '06 GLXR Triton- *Gone and forgotten*
    Oct 2011
    Hunter Valley
    I've had my brakes done by a local independent garage without issues. Had pads and discs replaced, and the last time just pads. I have not asked them to clean the EPB brakes though - that was done by an LR specialist.
    Ron
    2016 D4 TDV6 Corris Grey
    2018 D5 TD6 SE Silicon Silver - gone
    2011 D4 TDV6 2.7 Indus Silver - gone
    IIDTool BT
    winglen is offline Fossicker Silver Subscriber
    Jul 2013
    I recently had Roverworks Canberra do my MY16 D4 rear disks at 65k and the wear indicator on. Such a good price I had them do the fronts too. $440 for the lot.
    Mar 2016
    I did the tears and referenced the Bodsy Brake Bible and found it a simple activity on a Disco.
    2007 Audi RS4 (B7)
    Jan 2017
    Whitsundays
    Two weeks after a service last month my brake wear indicator come in the middle of nowhere and over 1000 k from anywhere. On return a good look said it was time for rotors as well. To my surprise when doing the rears myself the inner left pad was down to metal and had gone undetected at service because the Computer told the indie all was good with the brakes.
    Lesson here is the wear indicator warning light while wear should be relatively even across the pads across a given axle but it will actually only tell you the state of ONE of the 4 pads and if there is a calliper issue your only way to tell is have look..... yourself. This particular pad was not one with the wear sensor. It would of happily ground down to nothing (as it did)
    Oh and if the wear sensor triggers that needs to be replaced too.
    Anyway relatively straight forward job with the right tools and following the above mentioned bodsy brake bible, no bleeding required and all good now. But.....computer said it was good???
    BTW sorted the calliper too.
    99.87 MB
    Quote Originally Posted by Konradical View Post
    Thanks.
    Are the factory pads actually Brembo anyway if you have the front Brembo calipers? On my Audi the pads are marked as Audi and also Brembo. That said, the Brembo pads are excellent high friction pads but they do produce a bit of brake dust for your shiny wheels - I have to clean them each week.
    Slunnie
    May 2009
    St Agnes, SA
    I am thinking I will give them a go. Brembo is a solid brand with a pretty good reputation. Will just need to decipher Rimmer Bros code and model application.
    When we got the car back, they left the repair sheet in the car as I have asked them to do for my records and I read that the rear brakes were "near" wear limits and that the wear sensor lead and height sensor lead were pinched. Presumably from when they had the rear apart last time. They replaced both under warranty.
    Dec 2009
    SW WA
    I'm yet to find a dealer of any brand of car that doesn't tell me that my brakes need doing at the next service.
    Oct 2017
    Quote Originally Posted by kenl View Post
    Yep. Service departments have targets like sales departments. Always brakes, rotors, and the good old "oh the inner of the rear tyres is worn and they both need replacing" is a good one too. If 50% of people agree then targets are easily met.
    I'm just so lucky my RR L405 sold this week (brakes done for RWC!) and I could find a beautiful high km 2014 Disco I can live with, pay off some debt and found an awesome independent LR specialist a 20 min walk from home in this process.
    Care to name the "Independent LR specialist" ... ? Always good to have alternatives...
