Results 1 to 10 of 11
Thread: Defender recovery points vs this
    May 2018
    Does anyone see a problem with these, tow bar based recover points for snatching vs the rings bolted to the chasis? Are the standard Def recover points good enough? What is best practice?
    Jun 2013
    Those things bolted to the chassis from factory are NOT RECOVERY POINTS.
    I’d be sus even of those “jate rings” people use to replace the factory tie-down points.
    Neil
    (Really shouldn't be a...) Grumpy old fart!
    MY2013 2.2l TDCi Dual Cab Ute
    Nulla tenaci invia est via
    Wheelers Hill, Melbourne
    I have exactly that set up & have snatched plenty with it. The rings are for trailer safety chains only.
    BTW, That's an interesting addition of the bolt to stop the towbar from vibration. My Deefer makes so many assorted noises, it would be impossible to tell if mine vibrated or not..
    austastar's Avatar
    Jul 2009
    Hobart
    Quote Originally Posted by DeeJay View Post
    Hi,
    It makes opportunistic theft a little more difficult in dodgy caravan parks too.
    Quote Originally Posted by austastar View Post
    Hi,
    On that subject as I'm too tight to buy a towbar pin lock, I just drilled out my pin & added a lock- hasn't filled with mud-yet..
    May 2018
    Quote Originally Posted by tact View Post
    Thanks. So what do people use for a recover point on the front if you’re it using a bull bar with additional fixings to the chassis rails? Even with a winch, I think you’d want a fixing point for a snatch!
    May 2018
    Was on the truck when I got it but it works really well. Just remember to take a spammer with you when you travel, but that’s a given with a defender!
    Jun 2013
    Quote Originally Posted by sizl View Post
    One way to go, doesn’t require a bull bar, is fitting under body protection that incorporates recovery points. Something like this:
    APT Steering Guard | Defender
    Neil
    Kilmore, VIC
    106.38 MB
    Same here. I have used small padlocks for the last decade like that. If you cut an old bike tyre inner tube (or similar) and wrap it around the padlock - that covers the lock and stops it from getting filled with dust, dirt, etc. but you can still easily access the lock when required.
    DiscoClax
    '94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
    '08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
    We don't allow spammers on this site!
