Here's a picture.
 Fossicker
						Fossicker
						Hi all. I'm just about to remove the front prop shaft on my 110 and would appreciate some advice.
After undoing one of the bolts I found that I can't remove it as the head of the bolt hits the transfer case.
My question is, will there be enough wiggle room to get the bolts out once they are all undone and the prop shaft moved forward ?
 Fossicker
						Fossicker
						Here's a picture.
Roll the vehicle forward and that will reposition the shaft so you can remove the said bolt
 Fossicker
						Fossicker
						Thanks. I'll give that a go. It's just that looking at I didn't see where it could clear the transfer case.
The bolts at the TF case stay in the yoke. You can slide the shaft forward alongs its splines to remove.
 Fossicker
						Fossicker
						 Fossicker
						Fossicker
						This thing.
Giving you want to test it slide some lager nuts or a bunch of washers over the bolt than put the nuts back on, this will stop the head of the bolt hitting the t-case
 Fossicker
						Fossicker
