Results 1 to 10 of 11
Thread: P38 fuel pump
    Nov 2008
    Bruthen, Eastern Vic.
    P38 fuel pump
    I would like to buy a fuel pump as an emergency spare, I have read that a Commodore pump is a suitable replacement, can anyone tell me which model Commodore pump fits?
    Or should I stick to genuine LR?
    Thanks,
    Terry
    Crafers West South Australia
    Depends on which model P38 you're talking about. '94 to '98 is GEMS injection and can use a VN to VR pump inside your original pump housing with some possible wiring plug changes. '99 on is THOR injection and uses a different pump. In any case you won't find a genuine LR one for sale, the vehicles are way too old now, only aftermarket is available. A VDO brand pump seems to be the most recommended replacement brand.
    Nov 2008
    Thanks bee utey, mines a MY 2000. I should have said that.
    I fitted a VDO pump into the TD5 Disco, seemed ok.
    I don't mind changing internals if needed, I just need to know things will fit when the old pump fails.
    Terry
    Aug 2018
    i purchased a VDO (not cheap) as replacement and will install it this week as the original is done well over 300k now, i will look at the one I'm pulling out and keep a spare, i guess some Walbro or Bosch would fit but can't tell yet
    mine blew a fuse once so I think it's about time to replace it
    Nov 2008
    Quote Originally Posted by DavidP38 View Post
    Mine occasionally makes unusual noises on cold mornings, that's what started me thinking about a spare.
    But I don't think it's a quick replacement, the tank has to come out apparently.
    I wonder if it has anti siphoning trickery like the D2 had.
    Looks like it has to be a VDO.
    Terry
    There are plenty of Thor RV8 fuel pumps on ebay for about $120.
    Nov 2008
    Thanks Garry, I'll have a look.
    I bought the D2 version one year ago for $107. Fuel Pump Module Assembly for Land Rover Discovery 2 1998-2004 V8 4.0L 4.6L | eBay
    Not sure if the P38 ones are the same but they also have the Commodore versions.
    I guess you pay your money and take your chances but for the price it was worth a chance - seems the same as the OEM one but I have not as yet fitted it - OEM are very expensive.
    You might want to look at this thread. Fuel tank differences between GEMS and Thor
    Towards the end, there are pics I took of the floor cutout I made to access the pump. I have the dimensions here somewhere.
    Nov 2008
    Yes I bought a 2 stage VDO one for a D2 TD5. about $300 I think. Petrol one should be cheaper, I hope.
    Terry
