Just measured the gap on my D3 S, bit variable for what I thought was factory fittedThe bottom of the strips is between 50 and 58mm up from the longitudinal panel crease along the lower part of the doors; and between 125 and 133 mm up from the top of the plastic trim along the bottom of the doors (below the panel crease).
Hope that helps,
Nathan
