Results 1 to 10 of 22
Thread: 200tdi seized I think
    Brisbane, Queensland
    I bought a 200tdi wagon a few months back with bad blow by. I thought I would have ago at trying to fix the problem with a couple of doses of oil flush. 15 min into the second flush came a quick hammering type of tone from the motor. And before I could shut the motor down it went bang. And is now seized solid.
    Here’s a pic of the blow by not long before it went bang.
    Any suggestions about what let go?
    Thanks.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Free Again Thanks Dan
    Spun a bearing Drop the sump.
    Aug 2012
    Logan,Queensland
    Big End bearing is my guess.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Thanks. The speedo indicates this Defender has low km for age. Why would a bearing go?
    REMLR # 137
    Aug 2012
    Logan,Queensland
    Prime suspect, maybe the oil flush thinned the oil out too much.
    Blocked filter from the flush actually doing its job, combined with the filter bypass not operating, if they have a bypass.
    Just guess work really.
    How many low k's on it
    Choices are vast now.
    Ls3
    300tdi
    Isuzu
    Ev
    HS2.8 TGV Powered
    Thanks for suggestions.
    This was 2nd flush. New Caltex oil and filter, & 1/2 dose of flush. I can’t recall km exactly but under 200k. Family is storing it for me so don’t have access right now.
    Keep suggestions coming.
    REMLR # 137
    I have a perentie chassis/motor and new gearbox. So unless this is worth fixing the body will be going on the perentie. Will fit a turbo to the perentie while the body is off.
    REMLR # 137
    Aug 2012
    Logan,Queensland
    The blow by is a worry in itself for low k's.
    With being low k but high age, maybe the timing belt has let go. Back the rockers off and see if it rotates. This would probably best case scenario.
    HS2.8 TGV Powered
    Timing belt is a possibility. I don’t know if it’s ever been done. The PO didn’t know.
    REMLR # 137
    Mar 2007
    Canada
    A timing belt break won’t seize the engine. The push rods bend instantly.
    Time for a rebuild.
