Thread: Rear wiper staying on
    May 2009
    Has anyone experienced a rear wiper staying on on a soft dash Range Rover, it stays on intermittent mode, feels like I have tried all combinations of on and off including dash button and wiper control lever.
    Can anyone help?
    Apr 2015
    Hervey Bay
    I'm sure the rear wiper on a softy is only controlled via the 2 buttons on the dash. The wiper will stay on when you press the washer button, and intermittent on the off/on button. So the off/on button is where the problem is. Maybe a broken or stuck button.
    I do remember that my old D2 you could change the intermittent timing of the rear wiper with front intermittent control on the wiper stalk, but that doesn't seem to work on the softy. Also the it doesn't have the reverse gear function.
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    May 2009
    Quote Originally Posted by FisherX View Post
    Why would a wiper stay on when you press the momentary wash button? Isn't it press, do a wash and 3 wipes and switch off?
    Or do you mean stay on for a few wipes?
    It seems to be stuck on intermittent mode, like turning on every so often.
    I have a feeling it is connected somehow to the main wiper intermitant.
    Will try dash on/off switch.
    Does anyone have a softy manual that shows how it all works?
    Oct 2011
    Fremantle WA
    Quote Originally Posted by blackrangie View Post
    Maybe I'm going blind, but just scrolled through 84 WIPERS AND WASHERS, 86 ELECTRICAL and couldn't find anything in my MY95 Workshop Manual
    Oct 2011
    Fremantle WA
    Quote Originally Posted by gavinwibrow View Post
    Just found this in the owners manual. I'm sure you've done it, but possibly wiper just not switching off after use?
    EDIT - pdf wouldn't paste but words are
    after continuously wiping 3 or 4 times, the wiper operates intermittently (approx every 6 seconds) UNTIL TURNED OFF.
    Apr 2015
    Hervey Bay
    G'day Gav,
    I was probably a little vague.
    I meant that when you press the wash button the wiper will work continually until you release it, then another couple of wipes after.
    And the on/off the wiper will work intermittently (well after the first couple of wipes) so as your problem is with the wiper running intermittently, it would be the on/off button or its circuit.
    91 Kawasaki GPZ900R
    May 2009
    Yeah, i think it may be wired wrong, as it doesn't need to be turned on to be able to press intermittent
