Thread: Bolt that keeps working loose - arhhhhh
    Mar 2011
    Cairns
    I'm wondering if I can afford to lose it? It's in a pig of a place to get at and just can't get mechanical tightening on my own.
    I've no idea if the loss of this one (clearly not doing a proper job as it currently looks) is going to be problem? Location is down low, front passenger side, look in behind the wheel. Unthreading itself back out towards the rear.
    Jan 2017
    Geraldton WA
    Loctite
    4.6m Quintrex boat
    Exactly - when that bolt was installed at the factory it would have had that blue locking agent on the thread - with the bolt being undone/coming undone a few times I guess the original locking agent has long lost its usefulness. I would use a strong grade locktite and it should be OK.
    garry
    loctite 680, loctig, migloc, or replace it with a serrated flange bolt with no washer.
    mikeford Guest
    Overdo
    Strongest loctite and a spring washer. If it does it again, the welder!
