Easy conversion, just need a couple of bits:
bell housing, fly wheel, fly wheel housing, clutch and presure plate, crank extension and bearing, extended clutch push rod, 12 volt alternator and starter motor [24v on most trucks]. Dependiing on the age of the isuzu, one of two different oil filter adapters.
All these bits are 'land rover specials'
Best bet is to find an isuzu stage one landy or 110 thats stuffed. even if the motor is buggered all the conversion bits should be fine.
