Results 1 to 10 of 13
Thread: Air Bag issues fitting Bull Bars
    Jan 2019
    Katherine NT
    I have been told that if one was to fit a bull Bar to Disco 3 there would be a danger of improper installation, where'as the Air Bags could be affected. Any one know about this?
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Laurie 123 View Post
    Not true or else ARB and OL wouldn't engineer and produce them. A home or custom built bar possibly but who wants to be the guinea pig.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    So the thousands of D3s out there with bullbars have issues - just think it through for a minute.
    As long as the D3 bar has the D3 compliance sticker/plate on it then there are no issues.
    Feb 2005
    Follow the instruction from the supplier of an approved front bar...all should be good
    Jul 2018
    Cranbourne
    Where would the compliance plate be?
    Mar 2007
    Warwick Qld
    There should be a visible plate or sticker on the bar stating what vehicle it is compliant with
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Jan 2019
    Katherine NT
    bull bar intallation
    mmm yeah well this is information given to me by RJ motors in Katherine Says if not installed correctly can trigger air bags .Think he is after a bit of business. hehehe
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by donh54 View Post
    On ARB bars its on the inside lh side.
    1974 VW Kombi bus
    NSW Far South Coast
    I think the RJ Motors man is having it on.
    My understanding is that bull bar attachment could not possibly ignite air bags as they are set off via 'decelarometers' which I think are mounted under the centre console in the D3.
    The main reason bull bars have to be designed properly is so that the 'crush cans' are still operational as the first point of collapse.
    Dec 2009
    Baldivis WA
    The bit in bold is correct.
    If you decide to substitute nuts/bolts for different spec ones, or modify a bar designed for a different vehicle, then there is a possibility the airbags could trigger when not required or not be triggered when they are required.
    Companies like ARB, OL, TJM test their bars to ensure correct operation of the vehicle airbags.
    So if you fit an ARB D3 bullbar to a D3 using the supplied hardware/nuts/bolts and fit it in accordance to the ARB fitting instructions you’ll have no issues.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
