Results 1 to 6 of 6
Thread: remmoving air conditoner from inside defender cab
    Mar 2010
    victoria
    i'm in the process of giving the dash a refurb and would like to give the air conditioner a spruce up too (repair crack and repaint outside)
    the dash is removed and the air conditoner seems to be oly attached to the pipes.
    how do i remove it? do i have to de-gas or can i switch something off first?
    NSW far north coast
    You need to recover the refrigerant, you can't pump them down.
    Make sure you cap and seal everything really well, as in almost gas tight.
    Also the loom is a PITA from memory, I think I just cut mine but I was tossing the lot
    Mar 2010
    victoria
    Quote Originally Posted by rick130 View Post
    how do i recover refrigerant?
    would it be easier to get it regassed afterwards?
    Oct 2007
    Wantabadgery, N.S.W.
    I believe it's illegal to release the gas into the atmosphere, as it's very bad for the environment. An auto electrician will recover the gas for recycling (or destruction), then return later to re-gas for you.
    Don.
    NSW far north coast
    You need the right gear and technically need to be licensed to work on any form of AC or refrigeration.
    Being in the industry and having to conform to the rules to keep my license and avoid massive fines I can't really suggest otherwise.
    Having said that a small top up on the systems I work on is often 40-80kg of gas......
    Mar 2010
    victoria
    ok, i might spruce it up in situ or leave it until the air con needs regassing
    thanks for advice
