Results 1 to 10 of 21
Thread: MY12 D4 - individual doors not locking or unlocking
    Feb 2011
    Hobart, Tasmania, Australia
    Question MY12 D4 - individual doors not locking or unlocking
    Our MY12 has developed a new trick where not all the doors are locking or unlocking.
    When locking the vehicle all doors lock except for the drivers side rear passenger door which can be opened (on doing so the alarm sounds). If this door is manually locked from inside then it cannot be opened externally.
    When unlocking only the drivers front door and the tailgate/tall door unlock. All other stay locked. They can be manually unlocked from inside the cabin and then the external door handles operate.
    A scan using the IID Tool provided:
    L319 - Discovery 4 2012Vehicle scanned on 08-03-2019 10:54
    Using IIDTool BT V3.0 B2643
    BCM-Body Control
    • U0214-00 (28) Lost communication with the remote function actuation
      ( on 03-03-2019 14:39:06 at 153846 km )
    DDM-Driver Door
    • B110A-11 (2F) Rear door driver side central locking motor - General electrical failure - circuit short to ground
      ( on 07-03-2019 17:13:54 at 153847 km )
    • B1164-15 (6C) Right mirror heater output - General electrical failure - circuit short to battery or open
      ( on 07-03-2019 17:00:27 at 153846 km )
    FCDIM-Front Control
    • U2101-00 (0F) Control module configuration incompatible
    PDM-Passenger Door
    • B1109-11 (2F) Passenger's door central locking motor - General electrical failure - circuit short to ground
      ( on 03-03-2019 17:38:18 at 153846 km )
    • B110B-11 (2F) Rear door passenger side central locking motor - General electrical failure - circuit short to ground
    After clearing those and having a play with the doors, locks and the SmartKey and then scanning again it provided:
    Vehicle scanned on 08-03-2019 11:19
    BCM-Body Control
    • B1B01-87 (2E) Key transponder - Bus signal/message failure - missing a message
      ( on 08-03-2019 11:18:26 at 153856 km )
    DDM-Driver Door
      ( on 08-03-2019 10:58:11 at 153852 km )
    FCDIM-Front Control
    PDM-Passenger Door
    • B10EC-15 (2E) Passenger's door double locking motor - General electrical failure - circuit short to battery or open
      ( on 08-03-2019 10:59:14 at 153852 km )
      ( on 08-03-2019 10:58:07 at 153852 km )
    B110A-11 (2F) Rear door driver side central locking motor - General electrical failure - circuit short to ground, U2101-00 (0F) Control module configuration incompatible, B1109-11 (2F) Passenger's door central locking motor - General electrical failure - circuit short to ground and B110B-11 (2F) Rear door passenger side central locking motor - General electrical failure - circuit short to ground are common faults to both scans.
    Any insights in how to resolve? From what I have read the door lock actuators have a high failure rate on the D3/4. When they fail, do they result in error codes such as the above? I.e. would the above error codes be caused by those three doors having failed actuators so the solution is to just replace them (e.g. following DISCO3.CO.UK - View topic - Replacing door latch / window regulator - Now with guide ), or would it be something more sinister?
    There was also a Check Engine Light issue faults due to the 'Intake air temperature sensor 1' that I assume is a seperate issue so have not quoted above, and have posted about in https://www.aulro.com/afvb/l319-disc...ml#post2890193
    Hornsby
    Quote Originally Posted by twr7cx View Post
    I had a similar problem with the driver’s door I cleared all faults and after an interstate drive the problem hasn’t come up again so I put it to some issue with my car battery. I have also reprogrammed all my keys with the IIDTOOL as I got a 3rd key and noticed that all keys respond better now, when previously I thought I had battery problems in the keys as I had to press lock/unlock buttons multiple times to get them to work.
    DiscoMick Guest
    I don't know about D4s, but when one of the rear doors on my Defender stopped working on the remote, but could be locked manually, it turned out to be that a wire which runs through a conduit from the centre pillar to the door had broken. Reconnecting the wire fixed the problem.
    Does your D4 have a wire running through a conduit from the centre pillar to the door? Might be worth checking.
    Feb 2011
    Quote Originally Posted by goofyr View Post
    I just programmed two new keys with the IIDTool and they have the same issue.
    Watched a couple of YouTube videos about the failed door lock actuators in D3/4's and looks to me like that's likely what the problem is as the interior lock latch does move just a tad from the motor which is what they generally did in the videos of the failed units too. I've seen some discussion about it generally being the motor brushes that go and that they're a fairly common standard size so will pull one out and take a look.
    Dec 2009
    SW WA
    It is not so much that the the brushes go, they just gunk up, I pulled one apart and cleaned up the brushes about 5 years ago and it is still going, in the mean time the replacement actuator (bought on aliexpress) still sits in the drawer.
    Feb 2011
    Quote Originally Posted by kenl View Post
    Handy to know.
    I noticed last night that Aliexpress has them available for dirt cheap. Any thoughts on the build quality? From the number of failures it would seem that genuine quality is a bit lacking anyways...
    Dec 2009
    SW WA
    I haven't had the opportunity to compare them side by side but the new unit looks good and seems well put together. I would not be at all surprised if they are from the same factory, I also recall that the same unit is used in other cars as well? But not sure on that one..
    Feb 2011
    I believe D3/4, Disco Sport and RR Evoque.
    Towcar Guest
    I think I posted a thread on this a few months back. $50 or so on eBay for a door lock actuator and 45 mins to replace, maybe 1 hr if first time...
    Feb 2011
    Quote Originally Posted by Towcar View Post
    Found it at Disco, RRS Rear Left Door Lock Actuator Replacement
    Happy with the quality of the eBay one? They’re holding up ok?
