As you will need to use a 1/4 drive or something similar in the same small size, just as tight as you can get it. You wont be able to over do it.
pay particular attention to all the rear ones as this is where I have seen them leak.
Another note, if you look through some old posts you will see somewhere I have recommended a steel pan with a alloy/rubber gasket that wont ever leak.
					 ZF 6HP automatic transmission metal sump pan - torque specs?
					 .  I thought they were the same forward of the rear gearbox cross member and then aft of that, things were different due to the shorter wheel base (that is why the L320 is technically better offroad with the same tyres than the L319
.  I thought they were the same forward of the rear gearbox cross member and then aft of that, things were different due to the shorter wheel base (that is why the L320 is technically better offroad with the same tyres than the L319 )
