Results 1 to 10 of 14
Thread: Benefits of Centre ATB when already have diff trutracs?
    Oct 2011
    Fremantle WA
    Hi folks. In my minuscule efforts to try and keep the economy going -what if any marginal benefits apply from fitting a centre ATB to a LT230 (with CDL) when trutracs are already fitted to front and rear diffs?
    Interested in comments from the many gurus on here!
    May 2015
    Williamstown, Victoria
    My ideal set up would be ATB diffs front rear and centre.
    Build date 11th Oct 2003
    LROCV #1410
    Mar 2016
    Adelaide
    Quote Originally Posted by Bohica View Post
    Sorry, but what’s an ATB?
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Oct 2011
    Fremantle WA
    Which is very close to what I'm considering, given the trutracs are a very similar beast.
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by John_D2 View Post
    Review: Ashcroft LT230 ATB centre diff
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    NSW far north coast
    It'd be interesting to drive.
    I'd really like to feel how it affects the under/oversteer balance using all three?
    One thing having an ATB in the t/case did is reduce the backlash there substantially.
    Probably not noticeable with an auto, but very much noticeable on a manual.
    Apr 2016
    Country Vic.
    Quote Originally Posted by rick130 View Post
    Same here .. mainly on the faster(ie. smooth) gravel roads that dominate our country.
    Gotta say tho, as is, on fast gravel, D1 handles just as I expected it too(like my old RRC), very predictable and quite neutral handling.
    my only issue ATM is some rear bump steer .. thinking either trailing arm bushes(to chassis) or maybe balljoint not quite in top nik .. kind of bump steer.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Even with perfect bushes the solid axle front will always have some panhard induced steering affect especially when the suspension is raised above std. Std suspension has minimal up lift relatively..perhaps done deliberately by LR to reduce steering impacts/inputs.
    Ever driven a raised yota or patrol? ...they wander all over the place😐 esp the rear whereas the rear on a disco is solid courtesy of the watts linkage.
    Feb 2011
    Hobart, Tasmania, Australia
    I've got the triple combo. Originally only had front and rear and then had the centre done on a whim. I really can't say I noticed anything particular after it though.
    NSW far north coast
    Quote Originally Posted by AK83 View Post
    Hey Arthur,
    I found with a little play in the lower rear trailing arm chassis bush the rear roll steer was pretty horrific.
    Check the A frame to chassis bushes too, the bolt and crush tube wear leading to bump steer and a clunk.
    I just hate using industrial bolts in double sheer clevises, threads aren't designed to bear loads!!!!
    I used to go rough through the race cars I used to look after and replace any SAE hardware with AN/MS/NAS spec bolts where you can specify the grip (unthreaded shank) length.
    They go up in 1/6" increments just so they can be used in shear.
    Or if I had to use socket head cap screws I'd buy too long and trim the threads to suit, often having to use washers as packers under the nut to get the grip length I needed.
    The wear on those big 19mm bolts for the A frame was scary!
    I just used genuine bolts as they are a known quality with the Deefer and made sure every bolt was correctly tensioned and crossed my fingers. Benefits of Centre ATB when already have diff trutracs?
