Results 1 to 10 of 11
Thread: Accelerator shafts - Series 3
    Jul 2012
    Hello from Brisbane.
    The Heath-Robertson accelerator set up for the 2.25 litre petrol engine in my Series 3 includes two cylindrical shafts. I am now missing one of them after they got mixed up in a shipment of parts that were sent to a powder coating firm and subsequently lost.
    The two parts are (236658) Accelerator Pedal Shaft and (577304) Accelerator Cross Shaft.
    Not sure which of the two I still have, but could work that out by trying it on the bulkhead.
    Anyway, my questions are:
    • Does anyone happen to know the dimensions of the two rods - i.e. length and diameter?
    • Does anyone have one on a wreck that they are happy to part with?
    Hopefully, around Brisbane......
    Also, not sure if the same parts were used on the Series 2A's as well?
    Neil
    1975 S3 88" - Ratel
    Jul 2012
    Solved.
    Hello again.
    Found the answers to both questions.
    Neil
    1975 S3 88" - Ratel
    Oct 2014
    Northern NSW.Australia
    Heath-Robertson accelerator ????
    whitehillbilly
    Jul 2012
    Quote Originally Posted by whitehillbilly64 View Post
    whitehillbilly
    Hello from Sherwood.
    Google “Heath-Robertson” and the meaning will be soon apparent.
    Neil
    1975 S3 88" - Ratel
    Jul 2012
    Quote Originally Posted by S3ute View Post
    Neil
    Hello again.
    Make that Heath Robinson and it will be even clearer.
    Age and memory issue there.
    Neil
    1975 S3 88" - Ratel
    Jul 2011
    Yarrawonga, Vic
    I googled "Heath Robinson" and it makes no sense at all to me in the context of Series throttle shaft. Please enlighten
    I should still have all the original shafts & linkages in my junk pile if you need them as I have 'fly by wire' throttle
    Jul 2012
    I googled "Heath Robinson" and it makes no sense al all to me in the context of Series throttle shaft. Please enlighten
    William Heath-Robinson was an English cartoonist who drew pictures involving exceedingly elaborate contraptions for undertaking relatively simple tasks. Something referred to as a “Heath-Robinson” generally makes that link.
    The throttle set up on a Series Land Rover is a case in point. All those rods, brackets, shafts, springs etc could have been replaced by a simple cable arrangement which is what was done with the Defenders and your own conversion.
    Keen to follow up on the shafts with you.
    Neil
    1975 S3 88" - Ratel
    Jun 2018
    Redesdale
    Neil
    A Rube Goldberg machineAccelerator shafts - Series 3
    Yes the series accelerator is much like one 🤣🤣
    Jul 2011
    Yarrawonga, Vic
    Neil
    OK that makes sense now. I'll rescue my shafts from the oddments box before they get repurposed.
    Jul 2012
    Hello again.
    Actually, it’s probably as well that Heath-Robinson didn’t design the throttle linkage. It would have been more complicated and there would have been an alarm clock to wind and the mouse in the treadmill to feed.....
    Neil
    1975 S3 88" - Ratel
