Results 1 to 10 of 14
Thread: Fault Code Reader in Tamworth, NSW? - Suspension Fault
    Jun 2018
    Tamworth
    Hi guys,
    Let me know if this is inappropriate but I just got back from a camping on the weekend where, when driving on dirt for an extended period of time, I got a lovely amber yellow 'Suspension Fault: Normal Height Only' error.
    The fault isn't there at the start and comes on after about 2-3 minutes or so of driving.
    Reading the forums I'm thinking it is the air compressor - it has never been replaced to my knowledge on a 2005 LR3.
    Before I commit to trying a repair kit or replacing the compressor I was wondering if anyone had a fault code reader I could make use of in Tamworth, NSW?
    Any advice would be greatly appreciated in troubleshooting or finding the best fix.
    Matt.
    Ellendale Tasmania.
    The local Ford dealer used to be a Land Rover dealer also, not sure if the Land Rover guy is still there though, I don't of any Indy Landy places in Tamworth unless there an AULRO Member nearby that has a code reader, next would Port Macquarie for a LR Dealer.
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    Jun 2018
    Tamworth
    I gave the local LR dealer a call. They quoted $99 just to read the codes.
    in the wild New England, NSW
    Quote Originally Posted by Parso View Post
    Tamworth Tax ?
    NSW SW Slopes
    You can pretty much bet that the fault is indicating that the reservoir pressure isn't increasing at an acceptable rate. The dryer's felt pad may be blocked with pulverised desiccant or the compressor may be weak due to a worn-out valve or piston.
    The next stage of failure will be that the compressor will be unable to get the vehicle up to normal height, at which time the vehicle will be dropped to the bump-stops. If this occurs then restart the engine and as soon as the vehicle is high enough to drive, remove the 20A engine bay suspension fuse before the fault re-occurs so that the vehicle can't lower. The 5A passenger compartment suspension fuse which supplies an ignition sense to the suspension module can then be removed so as to prevent the repeated 50kph messages which can be annoying.
    Jun 2018
    Tamworth
    Thanks Graeme! Would you recommend a rebuild or replacement?
    Oct 2012
    Suspension Faults
    Suspension Faults
    A good thread to read this one
    NSW SW Slopes
    I've not rebuilt either brand although I had replaced desiccant in an Hitachi attempting to avoid it being replaced under warranty. Some people have had success with rebuilding the Hitachi but many others haven't had much success.
    Jun 2018
    Tamworth
    Thanks guys for all the input. It hasn't dropped at all having been left at full height so I think I'm safe to go a new compressor.
    Could someone please confirm for me that this is the Hitachi I have already? I couldn't find a serial number anywhere I could get access to.
    I'm fairly sure but don't want to order the wrong one.
    NSW SW Slopes
    I'm sure that's not the Hitachi but its been a while since I dealt with the compressors.
