Results 1 to 10 of 15
Thread: V8 Replacement
    V8 Replacement
    So if I was to put a different, more fuel efficient engine in my Dii, as oposed to the technically flawed inefficient v8 what would it be.
    Right now to sell a v8 rover I'll be looking at a 15k loss so there is scope there.
    Diesels
    LPG
    Engine and tranny transplant?
    S.W. Sydney
    LPG & Petrol
    Tony
    Free Again Thanks Dan
    lpg is the cheaper option by far and you still have a v8 and cheap running costs if you do big ks it will pay for its self in no time
    ulp $1.35 a ltr
    lpg 44 cents a ltr
    diesel $ 1.42 ltr ouch
    god i miss my lpg rangie 8O
    HSVRangie Guest
    near Kilmore central Vic but work in Melb every day :(
    thanks HSV rangie (you saved me "spamming")
    I import the HS2.8 to oz any info anyone needs let me know
    Jase
    FYI if you don't know its basically a hot rod 300 tdi so can be bolted anywhere a 300tdi could fit
    NO computer
    same HP & torque as 4.6 V8 8) at waaay lower RPM 8)
    $10k inc GST 8O
    have 2 sitting on floor for imidate delivery
    What is the power and torque of your 2.8? Same as a 4.6 V8?
    Gazz
    the 2.8 factory specs are
    Max Power 135 HP @ 3800 RPM
    Max torque 277 lbf ft @ 1400 rpm 8)
    also these figures can easily be turned up in 10 mins with a spanner (no ecu to upgrade 8) )
    Jase
    2.8 importer
    Upwey, VIC
    Jase, have u finished installing your one in your p38 ?
    still waiting for bloody mecahnic (I know someone will tell him I'm bagging him here, but that's ok I tell him also )
    he is doing the major nuts & bolts install,
    I'm only doing fiddly bits (intercooler, exhaust, throttle cable ect ect) once he's finished (the intercooler is already in and half piped)
    he's been to busy wiyth other peoples jobs
    stop taking your landrovers there, I want him to do mine first
    He's also got my 110 sitting there for over a month, it only needs a few hrs work but he's to busy
    take my advise if you need something done as a quick don't use a freind who is a mechanic
    Jase
    Jase
    2.8 importer
    Did a google
    2.8 97kw/3800 rpm; 355nm/1600 rpm
    4.6 157kw/4750; 358nm/3000 rpm
    Can accept your claims for torque but a standad 2.8 has no where near the power of a standard 4.6.
    Gazz
